Don't fit: Front left and right panel
docsascha
(@docsascha)
Hi
Rather strange problem wit conversation Kit MK4 to coreOne
Right an left panel does not fit. Drilling in baseplate seems off half an millimetre or did I do something wrong?
Support is helpful but has no clue what's the cause
Some ideas?
Opublikowany : 05/07/2025 7:40 am
Raaz
 Raaz
(@raaz-2)
RE: Don't fit: Front left and right panel
They are VERY snug! Try to loosen the screw that's already in until it almost falls out, then try to get a screw into the other hole.
If that doesn't work, try to attach the currently not-screwed part first, then the currently screwed tight part.
Opublikowany : 05/07/2025 7:36 pm
1 ludzie polubili
iftibashir
(@iftibashir)
I recall also loosening some of the other screws off to get all three in, then driving them in equally........
Opublikowany : 05/07/2025 7:50 pm
docsascha
(@docsascha)
Solved, assembly problem
Did not fit the XY assembly (chapters) correctly down😱😱
Works fine now
Opublikowany : 06/07/2025 5:03 am
2 ludzie polubili
pixelbeans
(@pixelbeans)
The natural thing to do is to push to top XY frame down to get the extra few mm needed. Don't do this.
You need to remove the front left and right profiles.
Locate the gripper screw for the smooth vertical rods both sides. Loosen them up, then push down and retighten. That will give you the distance needed.
ie) the smooth rods still have more travel to do but have been secured so they're pushing the upper frame up too high.
I just had this exact issue.
Hope this helps.
Opublikowany : 23/08/2025 12:51 pm
1 ludzie polubili
Laura F Farrell
(@laura-f-farrell)
Yeah I had this on one side, I took off the corner profile, loosened both screws on the rod holder, rotated them around and bump, the weight of the gantry caused the rods to properly align. One that was done both sides fitted exactly. The fitting is very precise so even the slightest gap at the top of the smooth rod on one or both sides will cause issues aligning the corner profiles.
Opublikowany : 01/09/2025 10:50 pm
1 ludzie polubili
