Core One won't print second layer correctly
Stephan
(@stephan-3)
Mitglied
Hi all,
our Core One always prints the second layer in a spaghettified manner. I dont know what's the reason. I already changed the nozzle as well as the hot end. Calibrations all were perfect. No settings were changed neither in the printer, nor in the project file. I'll attach a picture to show the problem rather to explain it. Any solution to this would highly appreciated.
Thanks in Advance
Spaghettified Second Layer
Veröffentlicht : 09/06/2026 8:59 am
RE: Core One won't print second layer correctly
Posted by: @stephan-3
Hi all,
Thanks in Advance
What filament did you use? Did you dry it first? Do you get the same with any filament you try?
Veröffentlicht : 09/06/2026 1:54 pm
Also, is the nozzle and heat block correctly inserted into the heatsink? Are the thumbscrews tight?
Veröffentlicht : 09/06/2026 2:02 pm
Stephan
(@stephan-3)
Mitglied
Hallo Hyiger,
thanks for the speedy answer. I use Prusament Galaxy Black (PLA), the Nozzle temperature is 230° (first layer) 210° (others), the thumbscrews are tight and I checked nozzle and heatblock more than twice. Maybe a calibration matter? Though I did the calibration too (more than twice). all calibrations were good and passed. If you need further details about configuration I would provide you with that.
Veröffentlicht : 09/06/2026 2:15 pm
