Core One: How does the side filament sensor work?
Pagina 1 / 2
OA007
(@oa007)
Utenti
May be an obvious question to some, but I had a print that spanned multiple spools yesterday, and only the extruder sensor gave me the out of filament warning. I was able to swap the filament without issue, but it meant that I had to pull the PTFE tube quick release on the Extruder instead of pulling it out of the side insert.
Should the side filament sensor have stopped the print?
The side sensor passed the startup checks, but it is a kit build so possible that I did something wrong.
Postato : 09/05/2025 2:22 am
iftibashir
(@iftibashir)
RE: Core One: How does the side filament sensor work?
I've wondered the same TBH...the filament is too far in when the first sensor is triggered. I havent had a runout yet but assumed the printer would sense this and then the extrduder would retract enough so you can grab the end to pull the remaining filament out......
Postato : 09/05/2025 11:28 am
yblaser
(@yblaser)
Posted by: @iftibashir
I've only had one filament run-out and wasn't there to see it live but there was still about a cm of filament sticking out of the PTFE tube by the spool that I could grab so I assume what you described is what happened.
Postato : 09/05/2025 2:01 pm
2 persone hanno apprezzato
Eddie
(@eddie-3)
Utenti
I just had an issue where the roll ran out, however the filament was pushed to just inside the end of the PTFE tool.  There was not way to grab the end to pull it out.  In the end I remove the PTFE tube from the extruder, pushed the filament 1/2" or so, and was able to grab the end.
Is there a better solution?
Postato : 14/05/2025 9:55 pm
1 persone hanno apprezzato
Posted by: @eddie-3
Was that after you let the printer "unload" the filament via the menu, i.e. let the extruder push the filament back? I thought the distance between the actual side filament sensor and the end of the short PTFE tube is chosen such that the extruder can push the filament back just far enough to make it accessible.
Alternatively you can let the printer purge the old filament strand out through the nozzle and follow up with filament from a new roll which you push in manually until the extruder grabs it.
Postato : 15/05/2025 5:22 am
Posted by: @oa007
After I had built my kit, the side filament sensor got stuck in the "I see filament" position once I inserted the first strand of filament, then removed it again.
The little lever inside the sensor housing had moved freely when I installed and checked it according to the build instructions. But it turned out that I had not pushed the flat magnet (which is 6 mm wide instead of the advertised 5 mm) into the plastic lever quite far enough. So it stuck out just far enough to touch the lid of the sensor housing once that was installed, jamming the movement of the lever enough to hold it in the "filament is inserted" position.
Opening the filament sensor housing and pushing the magnet down a few 1/10 mm further solved the problem.
Postato : 15/05/2025 5:30 am
5 persone hanno apprezzato
George
(@george-4)
I think there is a setting in printer somewhere ( will need to check once i'm home) that you get to toggle the filament sensors, which ones to be active. Perhaps it has to do something with that? The side sensor trigger is turned off?
Postato : 15/05/2025 8:28 am
darkmattermaker
(@darkmattermaker)
Check the value the side filament sensor is reporting. You can get to this in the Info --> Sensors menu. Does the value change appropriately when inserting/removing filament?
When this sensor detects run outs the printer pauses, retracts the filament, and unloads so there should be about 1cm of filament sticking out of the side PTFE tube so you can easily remove what's left without having to do disassembly inside the printer. Make sure the PTFE tube on the side mount is pushed fully into place. There should only be about 2cm of PTFE sticking out of the handle.
Postato : 15/05/2025 11:58 am
Eddie
(@eddie-3)
Utenti
The filament sensor is working correctly, it detects when I insert new filament and when the filament is removed.  The issue I have is when I ran the spool empty, something I try to avoid but happens, it detected the filament going past the sensor and stopped the print and retracted filament.  However it stopped just before the end of the tube, no filament was protruding so there was nothing to grab.  It was almost flush with the end of the tube, so it does not need to be retracted much more.
There was a suggestion on reddit, and I see a comment on the assembly instructions, to ensure the PTFE tube is pushed in all the way.  I tried that last night with a good amount of force but it did not move.  The length of the tube appears correct from the photos in the assembly manual.
Perhaps the bowden tube is not inserted all the way on the other side of the sensor, I'll check that today.  It appears that the path is just slightly too long.
This is PETG, not a flexible filament, there was no issue with it being pushed by the extruder other than it didn't go far enough.
Postato : 15/05/2025 12:10 pm
Paul Lacatus
(@paul-lacatus)
I have the same issue with the side filament sensor.  In Info>sensors>side filament sensor it shows INS/ 2 and no change if i take out or push in filament.  I can hear the ball actuating when I ous the filament , the conection on the Buddy expansion port is on "filament"  socket , I remember checking well the conection on sensor board when assembling , all was moving well but right now no reaction.
Postato : 01/06/2025 5:25 pm
Please check the magnet position, as described in my earlier post. It is a likely cause for the issue you describe.
Posted by: @paul-lacatus
Postato : 01/06/2025 8:21 pm
Paul Lacatus
(@paul-lacatus)
Done, Thank you ! Even the access to the side filament sensor is quite tricky , I do not like the rivets at all 😉
Postato : 04/06/2025 4:13 am
wbphelps
(@wbphelps-2)
If the side filament sensor is not working - always displays "INS" on the info - you may have a short in the wiring inside the sensor.  I found there was not really enough room for the wires that are supposed to be under the sensor circuit board, and they had gotten pinched and shorted out.  This caused the sensor to always indicate that filament was present.  You can check this by completely removing the filament from the sensor and looking at the Sensor Info on the Info menu.  I reworked the sensor parts to add a couple of mm to the wire channel.  I reported this to Prusa and they sent me a new cable and sensor.  Not sure if they will change the sensor housing or not, but I could upload my version to Printables if anyonen wants to try it...
Postato : 08/06/2025 4:56 am
Russ Young
(@russ-young)
Utenti
@jurgen-7 - I had this exact same issue. Built the kit fine, side sensor got stuck always inserted after not so long.
I opened up the sensor housing and it seemed to work just fine, I inserted a small bit of filament in and out and the sensor totally worked...
I experimented a bit and found with the top lid on the sensor case it started to stick. I was thinking of just running it with the lid off, but then I found your post, and sure enough my magnet was not properly inserted. Thanks.
Posted by: @jurgen-7
Posted by: @oa007
Postato : 11/08/2025 6:19 pm
Ozgar
(@ozgar)
Utenti
Exact the same thing happened to me, thanks for the tip!
Postato : 28/09/2025 5:30 am
chmax
(@chmax)
My sensor detects the filament and doesn't stick but it is difficult to load filament into it (just pushing in the filament seems not to work all the time) and adds a large friction to the filament movement (although printing works well even with tpu98a). Is this something other experience as well? I don't really want to dismantle the side wall to get at the sensor again if this is the normal behaviour...
Postato : 30/09/2025 9:33 am
Steve
(@steve-5)
@chmax,
I sometimes have difficulty getting the filament to pass through the side sensor.  I often find that cutting a "chisel" tip on the filament helps those recalcitrant filaments pass through.  The ultimate solution is probably a replacement of the sensor.  Here is a link to a re-design that is intended to dramatically reduce the force necessary to actuate the sensor.  I have not installed this myself yet (not ready to print TPU yet) but I have the parts printed and waiting.
Side Filament sensor for Flex
Regards,
Steve
Postato : 30/09/2025 1:03 pm
dgrabski
(@dgrabski)
Utenti
I just was dealing with the same side filament sensor issue - this was exactly what was happening for me too. Thank you for the idea.
Posted by: @oa007
Postato : 26/10/2025 12:49 am
Marino
(@marino-2)
I had a jam in the side filament sensor. Since the end of the filament in the spool is bended inside a hole in the spool, it seems that this bend was enough to get caught against the ball or the filament feed and break the filament.The printer continued printing because the stuck piece kept pressing the ball, so to the printer there was filament at the side sensor. Fortunately, the print finished with the remaining filament in the Bowden tube. After disassembling it to remove the piece, I took the opportunity to reposition the magnet, as @jurgen-7 indicated. Now I notice the difference when I load the filament: it feeds in much more smoothly than before. The magnet must have been rubbing against the cover too.
I think this is an important point to include in the assembly instructions.
Postato : 20/12/2025 11:33 pm
They do cover this in the instructions. I believe it is mentions to move the level manually to ensure it moves smoothly and is not binding anywhere.
Postato : 21/12/2025 12:54 am
Pagina 1 / 2
