Core One Camera mounting issue
Phil
 Phil
(@phil-16)
I cannot get the camera to hold firmly in the corner. It is as if the magnets are not powerful enough. What am I doing wrong?
Posted : 28/12/2025 3:51 pm
Posted by: @phil-16
It's likely that you have simply not found the right position yet. The magnetic mount does not register in a very obvious, positive way. The optical axis (camera lens) needs to be oriented at 45° relative to each of the metal corner profiles.
Edit: Maybe try it with the cable unplugged at first, so that can't interfere. After you get the feel for the right position, repeat with the cable plugged in.
Posted : 28/12/2025 9:05 pm
RE: Core One Camera mounting issue
I printed this mod: Core One Buddy3D Camera lid remixed to improve view of printbed, then used super-strong N52 magnets. It also gives me a much better angle on the print bed.
Posted : 28/12/2025 9:18 pm
NickAtNight
(@nickatnight)
You should be able to check the magnet strength on a metal surface outside of the CoreOne.  That should eliminate your concern about magnet strength.
It took me a few tries to find the correct orientation to get the camera to mount. Once I did it was very secure.
Posted by: @phil-16
Posted : 29/12/2025 5:32 am
