Core 1: severe underextrusion?
verthh
(@verthh)
Utenti
Moin!
Over the last days I upgraded my MK4S to a Core 1 and added the camera, filtration and MMU3.
The printer produced one normal looking nice first layer, than it stopped extruding correctly. During printing there are clanging noises which - I believe- come from the extruder.
No failure messages at all, all calibrations passed, MMU3 seems to do its thing.
What should I do next? I pushed the hotend up as far as I could, I did several recalibrations of the extruder gears, I tightened the extruder idler screws a little bit...
This is the wrecked beginning of a benchy:
Beginning of print:
Postato : 26/09/2025 1:39 pm
RE: Core 1: severe underextrusion?
It's possible the idler tension screws are too loose. Try tightening both 1/8 of turn each. Sounds like the filament is slipping on the extruder gear.
Postato : 26/09/2025 2:47 pm
chmax
(@chmax)
yeah, the standard setup for the extruder screws used for the mk4 series still apply! I recommend checking the full build instructions and check if you can spot any major differences in the way the extruder is setup...
Postato : 26/09/2025 3:16 pm
