Cooled-down and cured filament from filament loading sticks to noozle
Matthias Nagel
(@matthias-nagel)
I am new to 3D printing and have successfully assembled my Core One. Everything has gone smooth so far. Problems started when I tried to calibrate the filament sensor and during my first test print (the keychain).
When the printer loads filament it squeezes out some of the filament and asks me whether the color looks right. That part of filament cools-down, curses and does not fall off, i.e. it remains stuck to the noozle. The printer drags and pulls that short string of filament around during printing. The issue is reproducible and consistent.
I run into the problem the first time, when I calibrated the filament sensor during the initial setup. The material which the printer squeezed out remained on the noozle and interfered with bed levelling during the next step.
During my first test print the material remained on the noozle after filament loading and was dragged through the first layer.
My second tesr print was the two-color version of the keychain. When I changed the filament and the printer asked me whether I see the correct, new color, that hard piece of filament remained on the noozle.
Each time, I had to open the door and remove, i.e. pull off, that colled-down, hard piece of filament with needle-nosed pliers.
What's wrong here? I don't believe that this is "stringing", as far as I understand, "stringing" seems to be something different. For me as a beginner it seems as if the printer fails to "shake it off", if this is actually a thing.
Best Answer by Sedacrivity:
Quite normal .. I have a pincet lying around to pull it off.
Posted : 21/09/2025 11:46 am
Matthias Nagel
(@matthias-nagel)
RE: Cooled-down and cured filament from filament loading sticks to noozle
This is the piece of filament which the printer dragged around during the 1st test print.
I used the PLA sample which came with the printer.
Posted : 21/09/2025 12:02 pm
It's just the way it is when doing a filament change. I pull it off by hand. Look for the various nozzle wiper mods on Printables which should help with this issue.
Posted : 21/09/2025 3:42 pm
Sedacrivity
(@sedacrivity)
Posted : 21/09/2025 6:15 pm
