					                		Belt is touching a zip tie for fan housing - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/belt-is-touching-a-zip-tie-for-fan-housing/</link>
                <lastBuildDate>Fri, 08 May 2026 13:52:46 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/belt-is-touching-a-zip-tie-for-fan-housing/#post-785382</link>
                        <pubDate>Wed, 11 Mar 2026 21:57:46 +0000</pubDate>
                        <description><![CDATA[hyiger,
Thank you for your reply. Just found the comments in the assembly manual...seems to be a common problem. I am going to remove the zip tie entirely: the temp sensor seems pretty secu...]]></description>
                        <content:encoded><![CDATA[<p>hyiger,</p>
<p>Thank you for your reply. Just found the comments in the assembly manual...seems to be a common problem. I am going to remove the zip tie entirely: the temp sensor seems pretty secure without the zip tie.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Carl</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/belt-is-touching-a-zip-tie-for-fan-housing/#post-785382</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/belt-is-touching-a-zip-tie-for-fan-housing/#post-785306</link>
                        <pubDate>Wed, 11 Mar 2026 15:24:12 +0000</pubDate>
                        <description><![CDATA[Posted by: @carl-2 
I am now assembling the Core One and about half way through. One thing i have noticed is that the top belt teeth are in contact with a zip tie on the plate for the two f...]]></description>
<blockquote data-userid="176563" data-postid="785272" data-mention="carl-2">
<div class="wpforo-post-quote-author"><strong> Posted by: @carl-2 </strong></div>
<p>I am now assembling the Core One and about half way through. One thing i have noticed is that the top belt teeth are in contact with a zip tie on the plate for the two fans. Even when i put the belt under tension it is still in contact. Is this normal?</p>
<p>No it's not normal. The Core One Assembly Manual has a specific instructions to ensure the zip tie is pushed down enough that it doesn't interfere with the belt. I would remove the fan cover, cut off the zip tie and replace it but ensure it's flatter. You could even remove it entirely. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>hyiger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/belt-is-touching-a-zip-tie-for-fan-housing/#post-785306</guid>
                        <title>Belt is touching a zip tie for fan housing</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/belt-is-touching-a-zip-tie-for-fan-housing/#post-785272</link>
                        <pubDate>Wed, 11 Mar 2026 12:02:07 +0000</pubDate>
                        <description><![CDATA[I am now assembling the Core One and about half way through. One thing i have noticed is that the top belt teeth are in contact with a zip tie on the plate for the two fans. Even when i put ...]]></description>
                        <content:encoded><![CDATA[<p>I am now assembling the Core One and about half way through. One thing i have noticed is that the top belt teeth are in contact with a zip tie on the plate for the two fans. Even when i put the belt under tension it is still in contact. Is this normal?<a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/8bcef39a-belt9-scaled.jpg"><img class="alignnone size-medium wp-image-185061" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/8bcef39a-belt9-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/belt-is-touching-a-zip-tie-for-fan-housing/#post-785272</guid>
