Assembling base Issues for CoreOne.
Butters
(@butters)
Hi, I'm having an issue assembling my Prusa Core One at this page; https://help.prusa3d.com/guide/2-base-assembly_835498#838683. I have Four identical parts but two of those four have cut outs, I don't know which two are front and back. I know the other regular bases with no cuts outs are the left and right of the base.
I tried to post this in the CoreOne Assembling area of the forum but it doesn't allow me to post.
Best Answer by AvariCe:
The part with the rectangular cutouts is the front plate, and the one with the two holes is the back. The other two are interchangeable
Napsal : 10/07/2025 2:31 pm
AvariCe
(@avarice)
Napsal : 10/07/2025 6:22 pm
Butters
(@butters)
RE: Assembling base Issues for CoreOne.
There is only one other issue, the spacer pins. In the assembly manual the area to which the two spacer pins are to be placed which like a tab on the metal sheets. I don't see this tab. Instead what I do see is, is two holes which are horizontal for the back plate, was there a design change which was different then that of the manual ?
Napsal : 11/07/2025 3:30 pm
AvariCe
(@avarice)
You're talking about this, right?
If so, those holes are in the front plate, not the back. Facing the front plate, these holes are on the right side, in a vertical position with respect to the plate.
Napsal : 14/07/2025 7:01 pm
2 lidem se líbí
iftibashir
(@iftibashir)
Follow my video guide - link in sig
Napsal : 16/07/2025 9:48 am
Butters
(@butters)
Yes, those holes. I was informed by someone at Prusa support there is an upgraded front panel. I know many here may be saying; what is this upgraded front panel; how can it be.
That is all the information I have otherwise if I knew more I'd give the information. 🤔 🙂
Napsal : 05/09/2025 10:33 am
