"Absorbing Heat" on screen
j-martin
(@j-martin)
So i've just finally finished a Core One build.
Among a bunch of issues  - pressed print and on the screen in the mid upper left came the words "Absorbing Heat" and a number% that increased very very slowly and nothing happened till it got to 100% about 20 minutes later then it started a nozzle clean and failed. The repeat clean worked and its doing my first print now.
What is that "Absorbing Heat" about?
What heat, where?
Opublikowany : 23/10/2025 2:21 pm
j-martin
(@j-martin)
RE: "Absorbing Heat" on screen
And again.  Second print. now waiting 15 minutes while "absorbing Heat" just passes 60%
This rubbish. I cannot afford to wait 20 minutes before each print.
How do I stop this issue?
Opublikowany : 23/10/2025 2:41 pm
Posted by: @j-martin
It actually serves a purpose. However, it's confusingly named. What it's doing is waiting enough time for the print bed to reach thermal equilibrium and thermal expansion before probing starts. Not doing this could result in thermal expansion happening during the print and causing issues like the print popping off the plate because the z-mesh (from the probing) is no longer accurate.
That said, for low temp filaments like TPU, PLA and PETG that are also not prone to warping, I personally don't think it's needed and so I turn it off. To do this you select "Expert mode" in PrusaSlicer, go to the Printers -> Custom G-code -> Start G-code section. Look for G29 G ; absorb heat and change it to the following and save your modification into the user presets. Also for sheets like the BIQU Cryo, even for engineering filaments, it's debatable whether this is really needed.
{if filament_type[initial_tool] !~ /.*(FLEX|PLA|PETG).*/}
G29 G ; absorb heat
{endif}
Opublikowany : 23/10/2025 3:30 pm
3 ludzie polubili
Want to also add that not doing this for large prints could possibly result in the head colliding with the print and a subsequent layer shift. For small prints, I don't think it matters.
Opublikowany : 23/10/2025 3:46 pm
j-martin
(@j-martin)
Mmm.
this is a major issue then.
I do almost all my work in ABS and there is no way that if I have to keep this on is this is acceptable.
This is my 4 th Prusa ( have one each of Mini, mK3s and Mk4 and none of them do this  to this step and don’t have issues as described because they don’t do it.
If this is a function of this model and I can’t get rid of this issue I will be returning the printer. It’s making it unusable in my little farm because I can’t be waiting 20 minutes on top the usual nozzle and bed heat time.
I did my due diligence before I bought this printer and never found any mention of it. I think Prusa need to tell people that there’s a nearly 30 minutes “start” time before each print.
Opublikowany : 23/10/2025 8:33 pm
1 ludzie polubili
Comment out this line and it will stop doing it. Will that cause problems with your ABS prints? Don't know but you can experiment and see. I suppose making this a firmware option instead may be easier for some. You can create a Feature Request here: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues
G29 G ; absorb heat
Opublikowany : 23/10/2025 8:55 pm
1 ludzie polubili
There is indeed an enhancement request going back to the XL here: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3534
Opublikowany : 23/10/2025 10:01 pm
k1mu
 k1mu
(@k1mu)
You can always click on "Skip" when it's in "Absorbing Heat".
Opublikowany : 25/10/2025 12:19 am
coilsconnection
(@coilsconnection)
Thanks for the code, it works perfectly for me.
Opublikowany : 09/11/2025 8:32 am
mnentwig
(@mnentwig)
Same here, I usually skip it. No issues so far (first layer adhesion from print bed preparation, a different story)
Opublikowany : 09/11/2025 10:28 am
coilsconnection
(@coilsconnection)
Personally, I solved all my adhesion problems with 3DLAKE!!! Simple and effective
Opublikowany : 09/11/2025 11:04 am
Cédric
(@cedric)
My mk3s was faster for small prints since it just started right away, most of the times i skip the absorption for small parts, havent noticed anything bad yet. Be sure to have the latest firmware, i think they changed it a bit.
Opublikowany : 09/11/2025 5:46 pm
mnentwig
(@mnentwig)
sure, if I can only remember to renew the glue stick layer now and then (problem is, this works to well so you tend to forget it has some limits).
Sprayable sounds more convenient. Well, it's a non-issue on my end but for user error...
Opublikowany : 09/11/2025 5:47 pm
iftibashir
(@iftibashir)
Ha! I didnt even realise there was a skip option for this step! LOL
Opublikowany : 10/11/2025 9:16 am
Posted by: @iftibashir
There is, just that you have to be in front of the printer which is annoying. I've been doing some large PLA prints recently and have it turned off. I've been noticed warping off the plate in specific areas not related to the print sheet. I'll try with it turned back on.
Opublikowany : 10/11/2025 2:58 pm
1 ludzie polubili
j-martin
(@j-martin)
Just a follow up report on the heat absorption function ( and chamber heat function as well)
since I posted the original question I have printed hundreds of objects of lengths from a few minutes to up to about 8 hours. I print almost exclusively in ABS.
In every case I have skipped ( manually) both functions ( except a very small number where I simply started the print and went to bed, and  I have had no failures ( zero, absolutely none) relating to anything to do with failing to carry out the functions. I am in a tropical environment and my ambient room temperatures are never below about 20  degrees C even on the coldest days. Maybe that makes a difference.
The annoying thing is having to wait around for the various lead in steps till it presents the “SKIP”option.
Till now I have not done a change to the g code because I’ve been doing a bit of an audit on the results of manually skipping the steps.
But I think I’ve now proved the features are redundant. It seems to me the theoretical issues behind them are not real.
Once again I’d like to see Prusaslicer have the ability to remove them with a simple check box. I’m not that happy that I have to go  into something I am not skilled at ( editing g code. I have no experience in editing code and in searching for advice all I have found are flippant comments about commenting out the line g29 and save it. But I still have not worked out how, where to save, how to get it as the default g code and incorporate it into the g code so it will retrieve it every time I slice something) and potentially cause a problem.
Opublikowany : 06/04/2026 10:30 am
