Prusa Connect not showing MMU options
This seemingly started with the server downtime, but I cannot get Prusa Connect to show the options for my MMU3, like filament mapping and so on. The screenshot should be showing the tool selector, but it doesn't. I've tried resetting the printer and MMU3, even tried removing and re-adding the printer. Nothing fixes it. The printer can see the MMU3, but it just will not show up online.
RE: Prusa Connect not showing MMU options
The same for me, I found when I deactivate the MMU3, I have the Prusaconnect settings to configure the 5 pressure heads option. So 5 times the nozzle diameter and the option helped to the nozzle and highflow nozzle. If I activate the MMU3 in the printer myself, only a print head is in Prusaconnect. Something seems to be exchanged. I have the firmware 6.2.0 on it.
same on MK3.5S MMU3 not showing in prusa connect
same for 2 MK3S MMU2S both showing as "Original Prusa i3 MK3S/+"
but the printer image show the MMU...
can't find how to set printer type
