Prusa Connect API
Akuma
(@akuma-2)
Utenti
Prusa Connect API
Hello,
I was trying to to get the temperture data from the website given its API connection code but I find it difficult to figure out the correct connection with the HTTP. I tried the "often" suggested HTTP: "https://connect.prusa3d.com/api/v1/" but the error I am getting when I try to convert it with JSON is: "Expecting value: line 1 column 1 (char 0)" with temp = jsondata.get("nozzle, {}").get("temperature"). Is there a possible solution?
Postato : 06/03/2025 3:25 pm
Jan Vejtasa
(@jan-vejtasa)
RE: Prusa Connect API
Is there any update to this? Official API access would be so great.
My usecase:
We´re a makerspace and need to track how much fillament a user used. We use the FabMan system, and so we always know who uses the machine in a given time. With this timestamp, we could (if the API was accessible) fetch which print the user started, and thus know how much fillament he/she used.
Give us access to generating API keys for this:
https://connect-mobile-api.prusa3d.com/api/docs
Postato : 19/05/2025 11:54 am
Karim
(@karim-2)
We have the exact same use case as Jan. We are also a makerspace and use Fabman. We would like to connect Fabman with Prusa Connect to achieve seamless integration.
Postato : 22/12/2025 2:04 pm
Zakrzewiaczek
(@zakrzewiaczek)
I use the PrusaConnect API:
  1. go to  https://connect.prusa3d.com/  (in your web browser)
  2. Right-click -> Inspect (or Ctrl+Shift+I)
  3. Go to the "Network" tab and reload page (Ctrl+R)
  4. Find your printer's UUID query (example in the attached photo)
  5. The "Response" tab is the response from the API. If you want to use this in a program, for example, you need to be careful about cookies, which are necessary for proper login. To obtain a command to execute the query along with the appropriate cookies, do the following:
    - Right-click on the query -> Copy -> Copy as [...]
    This allows you to copy the command that will send the query together with the appropriate login.
Postato : 31/01/2026 1:02 pm
