Wishlist for future enclosure features/add-ons
Page 1 / 2
gruagach
(@gruagach)
Hey it’s never too early to start right?
Posted : 09/05/2022 8:22 am
gruagach
(@gruagach)
RE: Wishlist for future enclosure features/add-ons
To recap things it has or announced features that will soon be available
      Standard Features
  • aluminum frame
  • solid top/bottom
  • Enough internal clearance for MMU2S
  • External mounts for power supply and controls
  • Temperature/humidity sensor
      Factory Options:
  • LED strip
  • advanced filtration system
  • fire suppression system
  • mechanical lock
  • PSU cable quick release
  • carry handle
      possible future add-ons from Prusa mentioned in announcement
  • Active heater
  • Smartbox programmable control unit
  • Smart LEDs
  • electronic lock
  • RFID unit
Posted : 09/05/2022 8:49 am
gruagach
(@gruagach)
I would second someone’s suggestion from the announcement thread—sealed filament case—and suggest that it could be linked to the smartbox to keep track of % remaining via weight.
how about a power-cable solution for large farms?
Posted : 09/05/2022 8:57 am
MileHigh3Der
(@milehigh3der)
What is SmartBox?
Definitely would be interested in spool storage, but only if it kept it dry.
Posted : 09/05/2022 6:30 pm
Netpackrat
(@netpackrat)
A kit of plugs for what appears to be numerous open holes in the frame for mounting of options that many will not be using.
https://www.printables.com/@Netpackrat/models
Posted : 10/05/2022 12:35 am
gruagach
(@gruagach)
They will let us know in detail soon, but roughly speaking Prusa’s SmartBox will be a programmable control unit/interface for all the electronic features and official add-one such as multi-colored LED strips, electronic door locks, particle sensors, fans, and maybe heaters.
Posted : 10/05/2022 5:05 am
Paul
 Paul
(@paul-18)
Any room to add a platform drawer slides to pull the printer out of the enclosure without having to completely removing it from the enclosure?
Posted : 10/05/2022 6:48 pm
jsw
 jsw
(@jsw)
Those of you on the mailing list probably received a note announcing the official Original Prusa Enclosure.
https://blog.prusa3d.com/original-prusa-enclosure_67656/
It has a built-in temperature monitor (hmmm ... looks familiar, see below) 😉 and options such as LED lighting, fire-suppression (some items say EU only for this), fan with filter (no mention of it being temperature controlled), a lock to keep kids, burglars, and curious cats out, and various other things.
One thing I do like is the ability to run the power supply and/or control panel outside of the box.
I'm probably not in the market for this, since I added a similar 3d Upfitters enclosure about two years ago with my own temperature monitor/control, but had this been available then I probably would have gone with it.
Posted : 10/05/2022 9:42 pm
+2 on spool enclosure.
Posted : 11/05/2022 8:54 am
K7ZPJ
(@k7zpj)
  • Remote monitoring for the SmartBox with an API to create plug-ins so that you can monitor it with  Octoprint or Home Assistant.
  • Haribo dispenser with access control to prevent over consumption.
Posted : 11/05/2022 4:08 pm
How about a smoke detectors that will disrupt power when smoke is present?
Posted : 11/05/2022 5:57 pm
MileHigh3Der
(@milehigh3der)
Posted by: @cwbullet
And/Or over-temp sensor.  I was told that in garages that they use over temp sensors to detect fires because the the dust and particles can mess with he smoke detector sensors.
Posted : 11/05/2022 7:18 pm
also a great option
Posted by: @milehigh3der
Posted : 12/05/2022 12:00 am
Jason
(@jason-6)
I have ordered an enclosure. I would like to see a mounting brackets to connect a Repbox to the enclosure and feed filament to the MMU.
Posted : 12/05/2022 9:56 pm
Kyle
 Kyle
(@kyle-4)
i have 2 mk3s with mmu2s and was thinking the same, would be nice if had a  model of the enclosure to start designing parts.
i was thinking setting repbox on top with back overhanging and use bottom ports, just need some support for back of box
This post was modified 4 years ago by Kyle
Posted : 30/05/2022 1:19 pm
Jason
(@jason-6)
@Kyle that is looking good.  I will be interesting to see the filament paths into the enclosure
Posted : 12/06/2022 3:40 am
Win J.
(@win-j)
Nice!  I would love to see an option to include the RMU Mk3 from https://filamentbuffer.co.uk and the RepBox, if the RMU would fit.
Posted : 08/07/2022 2:04 pm
Kyle
 Kyle
(@kyle-4)
Think I would rather make a bracket on the outside for the rmu for ease of loading, then just run ptfe through the wall to mmu. I also run rmu on mine
Posted : 08/07/2022 2:33 pm
Crab
 Crab
(@crab)
The Temp/Humidity sensor on the Prusa looks like the $2 Aliexpress one. I’ve got 8 of those for my DryBoxes.. and I use Aqara’s temp/humidity sensor. ($22) (so often put both in a box.. the Aqara has the ability to notify me if the humidity goes above a certain value.. but I haven’t tested it yet) . What I’ve found is that that the cheap ones will tend to stay at one value and then take a large jump.. I find they stay at about 10 or 21% humidity.. seems weird.. Where my Aqara do seem to be more accurate.. (at least the numbers are all different in my 8 DryBoxes). So I think the Prusa humidity sensors would only be about +/- 10 (not 10%) in humidity readings. (In fact at humidity between 10-20%, the cheap sensor can be off by 100%, I estimate.   I’d like to see something more accurate.. Now I don’t have a reference humidity sensor to verify.. But putting 2 of the cheap sensors in my house, I’ll have one read 55% and one 65% for relative humidity.. For us in humid environments, I don’t find those cheap ones near as accurate as I’d hoped.
Posted by: @jsw
Posted : 08/07/2022 2:59 pm
Crab
 Crab
(@crab)
I think there is a real market for a 5-6 1Kg spool holder that has a small micro in it and a good humid sensor that would cause a heater and ball-bearing fan to only heat when necessary and keep humidity between 10-20%. I didn’t realize how much moisture will get into filament when I started this past-time only months ago. After I discovered the cause of my bad prints, I made about 8 DryBoxes, but changing desiccant can be tiresome. A little off topic of enclosure.. But a really high performance box that sips electricity could be a huge asset (and necessary) for those who what to use a small range of filaments for different prints and a nice accessory for an enclosure. I haven’t seen such a beast yet; maybe one exists.
Posted : 08/07/2022 3:09 pm
Page 1 / 2
