Pie in the Sky idea ? As the heat nozzel is metal can it be used as an anode ?
Hi
Good if one of you can quash this idea, with some additional logic. The idea that if the metal heat nozzel could be used add + charge to the surface of the printed filament,( realize the filament is an insulator but the VOCs should be very light) and maybe the base plate could contain a negative charge. Would the VOCs is light enough to be effected by this is a way that they would move the the base place. May still need an enclosure to insure the air remains still around the printer surface.
Very much aware that a little knowledge is a dangerous thing, which is why I am putting this out there for other to quash.
Regards Colm
Postato : 06/02/2024 11:08 am
