Does the filter add on have multi speeds?
meathead
(@meathead)
I have installed my filter and it only has a high speed.  You press the button once to start it and it runs very high.  I press it again and it slows down for about 10 seconds then returns to the high speed.  Is this correct?
Press one time - very fast
Press twice - runs slower than speeds back up like it was running before
Press third time - off
Thanks much!
Posted : 19/02/2024 10:37 pm
Brian
(@brian-12)
RE: Does the filter add on have multi speeds?
I've been using it for over a year now, daily on 2 machines and 1 speed works just fine. This is printing primarily PETG, and a little ASA & PLA.  I turn the fan on when the printer is warming up and off about 10 minutes after the print is complete.  You can automate this some with a cheap smart plug.
Why do you want to slow it down?
Posted : 19/02/2024 10:58 pm
meathead
(@meathead)
It is running in a room with a TV so slower speed would be quieter.  Some PLA I noticed give off a smell I think requires less filling than like say ABS?  That I would like to have a slower speed.
Does yours act weird when pressed twice like mine?
Posted : 20/02/2024 12:28 am
Brian
(@brian-12)
Posted by: @meathead
Yes it's not quiet, but mines in my basement so it doesn't bother me.  If you've got basic electric skills you could probably easily wire in a potentiometer to control the speed. I'm not sure you could get that functionality with the existing board unless they changed something.  My suspect is that it would require a different circuit board
Yes of you hit the button 2x quickly it acts weird because you tried to restart the motor while it was still spinning.
Posted : 20/02/2024 1:56 am
meathead
(@meathead)
I think I can live with it, just wanted to make sure something was not wrong with it while it is under warranty.  Thanks for your time and confirmation that I don’t have an issue with my hardware. 😀
Posted : 20/02/2024 9:04 pm
