					                		Stringing with high flow nozzle - Prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/prints-troubleshooting/stringing-with-high-flow-nozzle/</link>
                <lastBuildDate>Tue, 10 Mar 2026 13:17:23 +0000</lastBuildDate>
                        <title>RE: Stringing with high flow nozzle</title>
                        <link>https://forum.prusa3d.com/forum/prints-troubleshooting/stringing-with-high-flow-nozzle/#post-779135</link>
                        <pubDate>Wed, 21 Jan 2026 21:31:00 +0000</pubDate>
                        <description><![CDATA[Thank you @hyiger and @Ruebarb - for your advice. I will experiment and try to get it tuned in. Mark]]></description>
                        <content:encoded><![CDATA[<p>Thank you @hyiger and @Ruebarb - for your advice. I will experiment and try to get it tuned in.</p><p> </p><p>Mark</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prints-troubleshooting/">Prints troubleshooting</category>                        <dc:creator>mbiasotti</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prints-troubleshooting/stringing-with-high-flow-nozzle/#post-779135</guid>
                        <link>https://forum.prusa3d.com/forum/prints-troubleshooting/stringing-with-high-flow-nozzle/#post-779123</link>
                        <pubDate>Wed, 21 Jan 2026 20:19:55 +0000</pubDate>
                        <description><![CDATA[As Hyiger said, nozzle temp 1st. Print a temp tower. Once you have the best temp, then a stringing test file. I haven&#039;t used ASA and I don&#039;t use HF nozzles. But I have found for ABS &amp; PE...]]></description>
                        <content:encoded><![CDATA[<p>As Hyiger said, nozzle temp 1st. Print a temp tower. Once you have the best temp, then a stringing test file.</p><p> </p><p>I haven't used ASA and I don't use HF nozzles. But I have found for ABS &amp; PETG, PCTG, the default settings for Prusa PETG, in the filament overrides, worked for all 3 of those.  I would use that as a starting point to see any improvements. Wipe while retracting for PCTG made the problem worse. For the other 2 it helped alot.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prints-troubleshooting/">Prints troubleshooting</category>                        <dc:creator>Ruebarb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prints-troubleshooting/stringing-with-high-flow-nozzle/#post-779123</guid>
                        <link>https://forum.prusa3d.com/forum/prints-troubleshooting/stringing-with-high-flow-nozzle/#post-779117</link>
                        <pubDate>Wed, 21 Jan 2026 19:00:51 +0000</pubDate>
                        <description><![CDATA[@hyiger   -  Do you have any recommended value/s on increased retraction distance and speed?]]></description>
                        <content:encoded><![CDATA[<p>@hyiger   -  Do you have any recommended value/s on increased retraction distance and speed?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prints-troubleshooting/stringing-with-high-flow-nozzle/#post-779117</guid>
                        <link>https://forum.prusa3d.com/forum/prints-troubleshooting/stringing-with-high-flow-nozzle/#post-778992</link>
                        <pubDate>Wed, 21 Jan 2026 03:07:04 +0000</pubDate>
                        <description><![CDATA[That’s usual when switching to a HF nozzle. You can increase retraction distance, retraction speed and maybe lower the nozzle temp 10° or so.]]></description>
                        <content:encoded><![CDATA[<p>That’s usual when switching to a HF nozzle. You can increase retraction distance, retraction speed and maybe lower the nozzle temp 10° or so. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prints-troubleshooting/">Prints troubleshooting</category>                        <dc:creator>hyiger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prints-troubleshooting/stringing-with-high-flow-nozzle/#post-778992</guid>
                        <title>Stringing with high flow nozzle</title>
                        <link>https://forum.prusa3d.com/forum/prints-troubleshooting/stringing-with-high-flow-nozzle/#post-778959</link>
                        <pubDate>Tue, 20 Jan 2026 23:11:42 +0000</pubDate>
                        <description><![CDATA[I recently switched to a high flow 0.4mm obxidian nozzle on my Core One.  Without any changes other than updating my printers and connect settings, I noticed that I&#039;m getting some &quot;stringing...]]></description>
                        <content:encoded><![CDATA[<p>I recently switched to a high flow 0.4mm obxidian nozzle on my Core One.  Without any changes other than updating my printers and connect settings, I noticed that I'm getting some "stringing" using my default ASA filament that I didn't have before with my standard nozzle.</p><p>It kinda makes sense given that the high flow nozzle is moving more material, but would like to correct it if I can in my Prusa slicer settings. Has anyone else experienced this and if so, did you correct it by changing your default setting/s?</p><p>Mark</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prints-troubleshooting/stringing-with-high-flow-nozzle/#post-778959</guid>
