PrusaLink 0.6.0 farm_mode and PrusaConnect Filament menu
madpro
(@madpro)
I like the new feature but seems like its only available (for now) if I enable farm_mode. Also - the filament setting once added to PrusaConnect does not make its way back down to PrusLink (yet). but its awesome!!
Posted : 21/12/2021 2:26 am
McBig
(@mcbig)
RE: PrusaLink 0.6.0 farm_mode and PrusaConnect Filament menu
The farm_mode do something different, and i thing that is not work now, because the solution was bad. Farm mod is idea, to operator can set MK3 printer to prepared state from LCD after print is done. At this moment, you can set printer as prepared only from Connect.
This state is for automatically print from printer queue, when all conditions are true.
And about filament, yes this is the first version, but we are not sure, which way is the right. Idea for PrusaLink is stay simple as can be, and all high level management should be in Connect.
Posted : 21/12/2021 11:06 am
madpro
(@madpro)
Thank you for the detailed response and information. Since we are in beta i thought to try it out. Looking forward to next updates!! Thanks for all the hard work.
Posted : 21/12/2021 4:08 pm
Timo
 Timo
(@timo-2)
Posted by: @mcbig
Have been using the printer queue more and more. It is an awesome feature. If Prusa could add 'set printer as prepared' to the LCD menu it would be perfect. So fingers crossed they can add it.
I have no special talent. I am only passionately curious
Posted : 28/12/2021 11:02 pm
