SUMO enclosure : where download plexiglas panel plans (dxf or plans with dimension)?
fabduchalet
(@fabduchalet)
Hello everybody,
i'm building a SUMO enclosure for my prusa XL.
All parts are printed.
All the BOM has been bought separately (not in a kit)
Now i will build panels (prbably not all in plexiglas). Do you know if i can download the plans of plexiglas pannels? With dimensions, angles, etc, etc
by advance, thanks, Fab
Napsal : 04/04/2025 2:50 pm
jprince
(@jprince)
Author/designer have no plans to release panel design/plans.
https://www.printables.com/model/712707-sumo-enclosure-by-3d-sourcerer-made-for-prusa-xl/comments
Could you post the DXF for the acrylic panels. I would like to re-make them out of Polycarbonate so I don't have to worry about the impending cracking. Otherwise this is a great kit with great instructions. I just would have liked an option to get Polycarbonate instead of acrylic.
 Reply  March 27, 2024 at 10:53 AM133D Sourcerer@3DSourcerer
@Thehead_11769 we will not be posting the DXF files. We spent thousands of dollars and hundreds of hours on this project. If we post the files, someone will undoubtedly start selling them against the license.
 Reply  2 likes March 27, 2024 at 11:24 AM11Thehead@Thehead_11769
@3DSourcerer Understood, can you at least offer Polycarbonate sheets as an option then? Acrylic is just not durable.
 Reply  March 27, 2024 at 11:26 AM133D Sourcerer@3DSourcerer
@Thehead_11769 we’ll consider expanding the product offering - it would likely be more expensive, so I’m not sure how many would be interested in that option but if we get enough interest, we can try it
This post was modified před 7 months by jprince
Napsal : 16/04/2025 2:10 pm
1 lidem se líbí
Brian
(@brian-12)
RE: SUMO enclosure : where download plexiglas panel plans (dxf or plans with dimension)?
Why would they give the drawings, your completely just stealing the design without paying.  I have no sympathy.
Napsal : 16/04/2025 5:55 pm
1 lidem se líbí
fabduchalet
(@fabduchalet)
Oh, i just understand their business model. I thought wrongly it was open source. Sorry for that and forget my question.
Napsal : 16/04/2025 6:31 pm
2 lidem se líbí
Brian
(@brian-12)
Thank you for explaining the misunderstanding.  If you have the ability to purchase the kit I recommend it.  I've been using a Sumo for a while now and I've been happy with it.
I even designed a Filtration system that uses the Prusa blower and filters.  It  attaches to the back of the Sumo.
Napsal : 16/04/2025 8:47 pm
1 lidem se líbí
DoctorWTF
(@doctorwtf)
I've been thinking about getting a Prusa XL and a Sumo enclosure, and developing some way to mount a chamber heater to the enclosure, which may require replacing one or more of the acrylic panels with something more heat-resistant. Which, in turn, means I'd need the dimensions of the panels being replaced.
Or is acrylic already heat-resistant enough to handle that?
Napsal : 04/05/2025 10:53 pm
jprince
(@jprince)
I believe you would be fine using acrylic for most materials. Acrylic will begin to soften at around approx 99 C or 210 F.
Personally I would be more concerned with the temperature affecting the electronics before I would worry about the acrylic.
This post was modified před 6 months by jprince
Napsal : 04/05/2025 11:01 pm
DoctorWTF
(@doctorwtf)
The issue here is that the heater is mounted right to the panel, and the temperature at the heater itself is obviously going to be a good deal higher than the resulting air temperature in the chamber at large. So you likely would want something other than acrylic, for a factor of safety if nothing else.
Napsal : 05/05/2025 12:00 am
