Small print removed from slice
Zachary Turner
(@zachary-turner)
Attached are two pictures from Slicer.  One sliced and one in view mode. In the two smaller versions of the text, the period is gone.  Are there print some settings I can use to get it back?
Opublikowany : 25/11/2025 4:57 pm
Steve
(@steve-5)
RE: Small print removed from slice
As this is a multicolor print did you perhaps inadvertently forget to change the color for those periods in the extruder selection? I ask only because I forgot once to select the "closed" space in a letter A once and the letter ended up filled instead :).
Regards,
Steve
Opublikowany : 26/11/2025 2:36 pm
