Pagina 2 / 2
Precedente
RE: PrusaXL always stops extruding mid-print, any material any speed
I found the lever locking parts tend to warp and heat up enough to allow enough play so that the tension is lost on the filament. The bolt and nut on the front of the lever lock has to be really tight and you must check it occasionally for tightness, especially if you are printing high temp filaments.
Postato : 29/08/2024 2:20 am
Pagina 2 / 2
Precedente
