PETG print - Supports are messed up
Revel
(@revel)
Have printed with this setup a lot. hardened .6 nozzle. Polymaker Polylite PETG 3k spool.  Generic PETG settings.
Same thing i've done in the past. Infact I did a print just like this on tool 2 (this one is on 4 in this picture) just a while ago and it wasn't perfect but far far better than what I am seeing here.
Not sure what is causing this. I think its even the same spool as the successful print.  The successful one has some issues but overall was fine.
Its not really damp in my house. I have a dryer but its for 1kg spools.
Respondido : 22/10/2025 9:23 pm
Revel
(@revel)
RE: PETG print - Supports are messed up
If it at all helps this is the Tool 2 print from yesterday, with the same exact spool and settings. It got this far (about 1/3 the way) and then stopped extruding entirely.  You can see it starting to fall apart leading up to it. My best guess is that the side piece was clogged. It was making ticking noises. But now i'm not sure.
Respondido : 22/10/2025 9:26 pm
