Has anyone done a successful multi-material print combining Prusament PLA and Woodfill Linden?
I'm trying to do a 1mm layer of PLA followed by 6mm of Woodfill and keep running into "stuck filament" errors when the woodfill print starts. If I print the object in either straight PLA or Woodfill it works fine. I am using the standard Prusament PLA filament setting and a custom PLA filament setting with 195 degree layers for the Woodfill. The PLA head is using the standard 0.4mm brass nozzle while the Woodfill head is using an ObXidian 0.4 mm nozzle. Any thoughts/input is appreciated. Thanks!
Opublikowany : 20/11/2025 5:04 pm
