Enable Wipe Tower with 2 different Materials/ Extruder
[Resuelto] Enable Wipe Tower with 2 different Materials/ Extruder
Plastikschmiede
(@plastikschmiede)
Hi!
I believe some of you may have encountered this message:
"The Wipe Tower currently supports non-soluble supports only if they are printed with the current extruder without triggering a tool change. (Both support_material_extruder and support_material_interface_extruder need to be set to 0). Shall I adjust these settings to enable the Wipe Tower?"
Currently, I am printing without a Wipe Tower because I am unable to print with different tools for various tasks (Perimeter, Infill, Support, etc.).
What am I doing wrong? I am quite sure that this was possible in an older version of the slicer.
In this particular case, I want to print a support structure in PLA and the part itself in PETG.
This setting would also be important for printing with water-soluble supports.
Printing without a Wipe Tower only works to a limited extent. The printer produces too many strings, and the print is not perfect.
Ideally, there would be a separate Prime Tower for each material.
Este debate ha sido modificado el hace 2 years por Plastikschmiede
Respondido : 02/06/2024 5:26 pm
1 les gusta
Plastikschmiede
(@plastikschmiede)
RE: Enable Wipe Tower with 2 different Materials/ Extruder
I realized I forgot to set the Top Contact Z Distance to 0 (soluble), so that was my mistake.
Respondido : 02/06/2024 5:35 pm
1 les gusta
ntdesign
(@ntdesign)
Apart from that, I set the wipe tower extruder to the PETG tool and add a few extra mm brim to the tower. This is 100% necessary for bigger prints, otherwise your PETG purge lines will not stay within the tower & the tower will eventually collide and be dragged around.
Make sure to create a PLA profile with bed temp = PETG temp. If you just use your normal PLA profile and increase the temp without saving, it will ignore that setting and the tower/print will come loose because it cools down when PLA is active. With these little changes I get fantastic surfaces reliably.
Very similar scenario to your print (frame with supported overhangs, but I'm using custom supports with solid top layers for better surface quality): https://www.printables.com/model/845676-low-profile-sbs-adapter-for-capillaries-and-nmr-tu
Respondido : 03/06/2024 12:19 pm
1 les gusta
MrDLP
(@mrdlp)
how do you add extra brim to the wipe tower?
Respondido : 10/04/2025 11:44 pm
zwacki
(@zwacki)
The wipe tower has a parameter "Wipe tower brim width". Should be visible in normal mode of Prusa Slicer.
Respondido : 21/04/2025 9:04 pm
zwacki
(@zwacki)
The newer Prusa Slicers can now select the tool head which determine the print bed temperature. If it works at all, haha, see my latest post...
Respondido : 21/04/2025 9:07 pm
