[Gelöst] USB Port Overcurrent
Benymo
(@benymo)
Mitglied
Hello,
I am having issue with Prusa XL with 5 Toolheads. When the printer is turned on, it resets during the loading and throws and error "USB Port Overcurrent #17306". This has been happening for quite some time now and I am waiting on update from Prusa Support.
This issue first occured shortly after a ruined print covered one of the toolheads in blob of filament. While cleaning the mess, the thermistor of the toolhead got damaged and it was replaced. But I am not sure if this is relevant to the issue.
What I have tried so far:
  • Turn printer on with disconnected toolhead where thermistor was replaced.
  • Turn printer on with all toolheads disconnected
  • Swapping display from Core One L and MK4s - Still same error when powered on
  • Testing display from XL on Core One L and MK4s - Display works as expected.
  • Using different USB drives, powering on with and without USB drive connected.
  • Bought and replaced LCD cable and Sandwich board (based on suggestion from 24/7 live chat support).
None of these fixes worked and the issue still persists. I am currently waiting on reply from the Prusa Support and will be trying another live chat support session soon. I have not found any damaged cable or components.
I will be glad for any suggestions on how to resolve this issue.
Thanks!
Happy Printing
Best Answer by Benymo:
Now that you ask, I belive a coleague was measuring it and there was no voltage, but I would have to try it again to be sure.
Fortunately I was able, after couple tries, to force firmware update through an actual USB drive and it seems that fixed the issue. I got couple seemingly random "Modular bed error" messages during calibariton but was able to print a benchy at the end and unload filament from all toolheads. So this issue seems to be FIXED now.
I will be doing osme more troubleshooting about the Modular bed error on Monday when back at work.
Dieses Thema wurde geändert Vor 4 days von Benymo
Veröffentlicht : 06/05/2026 9:19 am
Do you have any means of measuring the working voltage and current being drawn from the USB port?
Veröffentlicht : 06/05/2026 10:24 pm
Benymo
(@benymo)
Mitglied
RE: USB Port Overcurrent
Veröffentlicht : 08/05/2026 12:14 pm
