					                		Toolchange parameters .. single extruder MM printers - Ignore ? - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/toolchange-parameters-single-extruder-mm-printers-ignore/</link>
                <lastBuildDate>Tue, 17 Mar 2026 09:11:48 +0000</lastBuildDate>
                        <title>Toolchange parameters .. single extruder MM printers - Ignore ?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/toolchange-parameters-single-extruder-mm-printers-ignore/#post-711829</link>
                        <pubDate>Fri, 24 May 2024 04:23:07 +0000</pubDate>
                        <description><![CDATA[Are the parameters under &quot;Toolchange parameters with single extruder MM printers&quot; (under Advanced - Filament settings) all useless/ignored on the multi-tool XL? It seems that should be the c...]]></description>
                        <content:encoded><![CDATA[<p>Are the parameters under "Toolchange parameters with single extruder MM printers" (under Advanced - Filament settings) all useless/ignored on the multi-tool XL? It seems that should be the case as the header implies they are for the MMU, but I find no doc to state this.</p><p>I am just checking because I noticed some significant changes following a configuration update, and I want to confirm that I can ignore this annoying chunk of parameters that I wish I could hide/disable in PrusaSlicer if the case is as I expect.</p><p> </p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>MrBob</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/toolchange-parameters-single-extruder-mm-printers-ignore/#post-711829</guid>
