"Storage capacity exceeded" when trying to use Prusa Connect
Stránka 2 / 2
Dik Harrison
(@dik-harrison)
RE: "Storage capacity exceeded" when trying to use Prusa Connect
Correct, just 20, but after a bunch of those deletions, it went up to 40 each time.  I think it would be better to ask the user if they really want to delete all the selected files, and give the number of selected files.  From now on, I'm going to delete all files from the printer and Connect, and if I have made changes in PrusaSlicer, save them to my computer.
Napsal : 09/01/2026 7:45 pm
Dik Harrison
(@dik-harrison)
Thank you for the workaround, but I think I will use the previously described process to avoid this issue in the future.
Napsal : 09/01/2026 7:49 pm
Maturity
(@maturity)
It is a common UI model to have a checkbox above the list that implies everything in the list. You will often see this in webmail apps and the like
Napsal : 10/01/2026 1:39 am
gomi
 gomi
(@gomi)
This is the solution right here, you're a real saint.
I was so confused on why it kept saying my storage quota was full when I had deleted everything from the printer file storage & USB drive. Apparently the "Printer Files" are completely separate and was maxed out (which I'm assuming is the cloud storage).
Wish that was a bit more intuitive, but now I know for next time I guess.
Posted by: @sam-price
I TOTALLY get the frustration! I deleted everything off of my THUMB DRIVE except the firmware and no luck. BUT, this forum helped!!! Thanks!!
Along the VERY TOP of the connect.prusa3d.com webpage starting on the left it says:
    PRUSA CONNECT       Printers        CONNECT FILES       Help     Forum
Click on "CONNECT FILES" that's where the files are that are filling up the space on your Prusa Connect account.
Granted if the ERROR on Prusaslicer said that, it SURE WOULD HELP!!! Would have saved me hours of frustration.
Napsal : 07/02/2026 7:20 am
Stránka 2 / 2
