Startup freezes at "Connecting ESP"
Andrew Lindsey
(@andrew-lindsey)
Every time when I switch my Prusa XL on for the first time of the day, the startup process will hang with the message "Connecting ESP" and all of the fans on full. In order to get it to work, I need to press the reset button, at which point the printer will restart and then boot successfully. It's not a huge problem as hitting the reset button fixes it, but I would still like to fix it so it starts up without intervention if possible.
Posted : 19/11/2024 2:45 am
Pe3d
 Pe3d
(@pe3d)
RE: Startup freezes at "Connecting ESP"
I Had this Probleme with an older Firmware.
What Version are you using?
Posted : 21/11/2024 8:26 am
