Prusa XL Multi-Tool tool changer not enabled
anthdomingz
(@anthdomingz)
Membre
I am getting a 'tool changer not enabled' error on my 2 tool printer (that I have been using successfully for 2 years). When I go into calibration, I realized the menu is showing the options for single tool, not multi-tool. I am having trouble finding troubleshooting directions for this. I haven't changed anything mechanically.
Publié : 10/08/2025 2:27 am
Sova
 Sova
(@sova)
RE: Prusa XL Multi-Tool tool changer not enabled
What did you try alredy? Maybe try residing tool cable or factory restart maybe down graade the software or up grade the firmware. Alsow i run the printer without the metal electronics cover in the back of the printer because whit it it runs hot wich might damage it in long run. Some people have a problem with it a z axis control failing from ower heating.
Publié : 10/08/2025 10:56 pm
