					                		Prusa XL hotend clogged due to wrong temparture measuring? - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/prusa-xl-hotend-clogged-due-to-wrong-temparture-measuring/</link>
                <lastBuildDate>Sun, 07 Jun 2026 23:46:22 +0000</lastBuildDate>
                        <title>RE: Prusa XL hotend clogged due to wrong temparture measuring?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/prusa-xl-hotend-clogged-due-to-wrong-temparture-measuring/#post-684090</link>
                        <pubDate>Mon, 13 Nov 2023 19:52:12 +0000</pubDate>
                        <description><![CDATA[The idler was too weak and probably out of PLA which softened during longer prints, i got a reinforced one from here and printed it out of ABS]]></description>
                        <content:encoded><![CDATA[<p>The idler was too weak and probably out of PLA which softened during longer prints, i got a reinforced one from here and printed it out of ABS:</p><p>https://www.printables.com/de/model/596608-nextruder-modified-idler-lever</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Ragedude</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/prusa-xl-hotend-clogged-due-to-wrong-temparture-measuring/#post-684090</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/prusa-xl-hotend-clogged-due-to-wrong-temparture-measuring/#post-683977</link>
                        <pubDate>Mon, 13 Nov 2023 02:57:13 +0000</pubDate>
                        <description><![CDATA[Where? And what was actually the issue?]]></description>
                        <content:encoded><![CDATA[<p>Where? And what was actually the issue?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Mabau</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/prusa-xl-hotend-clogged-due-to-wrong-temparture-measuring/#post-683977</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/prusa-xl-hotend-clogged-due-to-wrong-temparture-measuring/#post-683970</link>
                        <pubDate>Mon, 13 Nov 2023 00:53:13 +0000</pubDate>
                        <description><![CDATA[jup, upgraded Idler made from abs works so far (found it on the prusaforum)]]></description>
                        <content:encoded><![CDATA[<p>jup, upgraded Idler made from abs works so far (found it on the prusaforum)</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/prusa-xl-hotend-clogged-due-to-wrong-temparture-measuring/#post-683970</guid>
                        <title>Prusa XL hotend clogged due to wrong temparture measuring?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/prusa-xl-hotend-clogged-due-to-wrong-temparture-measuring/#post-683843</link>
                        <pubDate>Sun, 12 Nov 2023 07:04:22 +0000</pubDate>
                        <description><![CDATA[Sooo, my Dualtool nextruder keeps getting clogged.
after unclogging it, it can do short prints, but with longer prints (~4hrs) it will stop extruding at some point, the nextruder gear tears...]]></description>
                        <content:encoded><![CDATA[<p>Sooo, my Dualtool nextruder keeps getting clogged.</p>
<p>after unclogging it, it can do short prints, but with longer prints (~4hrs) it will stop extruding at some point, the nextruder gear tears  chips out of the filament until it can no longer grab it.</p>
<p>i used my 2nd tool, and the standard-nozzle adapter, same issue.</p>
<p>-wont extrude again after getting unclogged</p>
<p>-temperature measured with a laser thermometer inside the hotends nozzle'thread <span style="color: #ff0000">reads around 40°C even though the built in sensor says 255° <span style="color: #000000">(also applies to the 2nd extruder)</span></span></p>
<p>i use ABS-T Filament from PM Filament (Prusa sold these in their shop back in the day, i used them with no issues for 5yrs in my 2.5S so i thrust their quality)</p>
<p>everything is Stock</p>
<p>I cant really make something out of this, except the temp sensor doesnt work properly after some time into the print</p>
<p>i didnt have problems with an old more stiffer ABS from 3d Jake or smt.</p>
<p>so just in case im wrong about the temperature sensor i will exchange the idler </p>
<p>for the updated parts some kind people made for TPU extruding, and hope that helps</p>
<p>(maybe the prusa parts get weaker from higher temp and cant put up the force needed for idling, so making them out of abs could help too)</p>
<p>Does someone have a similar issue, or even a fix?</p>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/prusa-xl-hotend-clogged-due-to-wrong-temparture-measuring/#post-683843</guid>
