Prints not rectangular
floger
(@floger)
Hi. This is my first post. Appologies if I missed the answer is already available.
My prints are not rectangular. I realized that when I printed the enXLosure. The diagonals of a full size square are at least 2mm off! When I measured the diagonals of the preassembled top frame I realized that this is is already out of shape.
How can I fix that? This isn't something that can be calibrated.
Napsal : 11/02/2024 12:01 pm
Lynn
 Lynn
(@lynn)
RE: Prints not rectangular
could you post an image to help us fully understand.  2mm across what span.
Napsal : 11/02/2024 1:12 pm
floger
(@floger)
Measure the two diagonals of a printed square or rctangle which is nearly the size of the printbed. One is 2 mm longer than the other one.
Measure from the corners between rear profile (in front of the print head bay) and Y rails to the diagonal edge of the other Y rail. One is 3 mm longer than the other one.
Napsal : 11/02/2024 2:20 pm
floger
(@floger)
It seems nobody has that problem and Prusa support has a hard time understanding the issue.
Since it is less important that the frame is parallel shifted, I preferred not to disassemble the whole printer. Instead I only removed the metal covers so I can reach the screws, that mount the X rail to the Y sleds. Then I loosened these screws, bent the X rail so it is perpendicular to the Y rails and retightened the screws. Additionally I glued some shimming on one side of the front stop, so the X rail touches both stops at the same time. Now at least the diagonals of the print are equal length.
I don't know how this went through quality control. Maybe prusa isn't aware, that in an XY-Core the rails have to be perfectly perpendicular to each other?
Napsal : 30/03/2024 3:01 pm
anderdog
(@anderdog)
I´m having this issue as well. Were you able to align it without loosening the servo motors? The screws between the rail and servo seems impossible to reach otherwise?
Napsal : 30/04/2024 12:08 pm
floger
(@floger)
You need to remove the side covers so you can reach the screws on the sleds. Then you need to loosen these screews push the sled on position and retighten them.
Then I shimmed the stop on the longer side side, so the sled bounces on both stops, since I didn't bother aligning the frame.
Loosening the servos does nothing to the alignment.
Napsal : 04/05/2024 5:33 pm
floger
(@floger)
Second picture.
Napsal : 04/05/2024 5:34 pm
ZeeKay
(@zeekay)
I'm running into this now as well. What are you using for square reference? Just against the linear rails? Mine doesn't sound as bad as yours, but still ~1mm over the distance of the whole bed it seems.
Napsal : 03/03/2025 9:34 pm
anderdog
(@anderdog)
I used a square ruler against the linear rails. Tried to shim them but that did not help. Ended up shipping the whole thing to Prusa and they replaced the rails.
Napsal : 03/03/2025 10:04 pm
floger
(@floger)
I am printing diagonal and compare the length.
Napsal : 03/03/2025 10:49 pm
ZeeKay
(@zeekay)
Ah that sounds fine enough. Looks like I'll be printing some X's. Contemplating cutting down a Allen key to fit under the sides instead of taking off the enclosure
Napsal : 03/03/2025 11:10 pm
