PDU for Europe?
Harshmage
(@harshmage)
PDU for Europe?
I might be taking a new job in Ireland, and will be shipping my XL over the pond, but I'm not too sure if the PDU needs to be swapped out for a different unit.  Or am I overthinking this and I just need a new power cable?
Prusa i3 MK2S, Anycubic Photon
Opublikowany : 30/01/2026 10:45 pm
RE: PDU for Europe?
I expect the answer depends upon where toy are coming from.
Ireland uses UK Standard BS1363 mains plugs  ( https://plugsocketmuseum.nl/British1.html)
if your current location uses different mains plugs, then you will need a different power cable with an IEC C13 connector on the printer end
( https://leadsdirect.co.uk/product-category/mains-leads-and-accessories/uk-type-g-mains-leads/uk-type-g-to-iec-c13/)
the prusa switched mode power supply itself should work on any normal mains voltage i believe it's input range is greater than 110 t0 240 volts AC
Opublikowany : 31/01/2026 12:13 am
Artur5
(@artur5)
See the wikipedia article on mains electricity for all countries  :
https://en.wikipedia.org/wiki/Mains_electricity_by_country#Plugs
This post was modified 5 months temu 2 times by Artur5
Opublikowany : 31/01/2026 10:07 am
