nextruder make clicking sound
Strona 2 / 2
Pe3d
 Pe3d
(@pe3d)
RE: nextruder make clicking sound
Check the Extruder and Filament path for debris or anything else. Maybe Just a partially clogged nozzle.
Opublikowany : 09/02/2026 4:06 pm
wessje1
(@wessje1)
I know where I can find the temperature. I am printing something, but it hasn’t gone wrong yet.
I have already tried this: (Try a cold pullTry to tighten the idler).
I am printing with PLA (Try setting your mvs to 12-18 max. (my petg settings))
I am printing with the standard settings from PrusaSlicer. (If you Take a Look at your sliced Print at the Speed. Is there Something Like faster layers?)
Posted by: @pe3d
To Show Heatbreak Temperatur
On your printer:
Settings/User Interface/Footer
There you can Show 5 different values during Print.
Try a cold pull
Opublikowany : 09/02/2026 4:09 pm
wessje1
(@wessje1)
I have cleaned it with compressed air, and I have changed the nozzle to a new one as well.
Posted by: @pe3d
Opublikowany : 09/02/2026 4:11 pm
wessje1
(@wessje1)
It hasn’t happened yet while printing. The temperature is 36 °C, and I will let you know what the temperature is when it does happen
Posted by: @jan-d-slay
Please read the heat sink temperature on the display during printing. I would like to know what temperature it shows when the noise occurs
I think the next step would be to find out what temperature the sensor measures.
Opublikowany : 09/02/2026 4:24 pm
1 ludzie polubili
Strona 2 / 2
