					                		Loading flexible filament into Prusa XL Nextruder - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/</link>
                <lastBuildDate>Wed, 13 May 2026 22:32:11 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-787567</link>
                        <pubDate>Fri, 27 Mar 2026 11:39:37 +0000</pubDate>
                        <description><![CDATA[I had loosened the idler screws by two full turns following the recommendationsWith very flexible filaments you have to back-off the idler until it is barely gripping - and it helps to make ...]]></description>
                        <content:encoded><![CDATA[<blockquote><p>I had loosened the idler screws by two full turns following the recommendations</p></blockquote><p>With very flexible filaments you have to back-off the idler until it is barely gripping - and it helps to make sure there is minimal tension in the supply so a really smooth spoolholder helps - but 60A is always going to be tricky so print *very* slowly.</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-787567</guid>
                        <title>RE: Loading flexible filament into Prusa XL Nextruder</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-787557</link>
                        <pubDate>Fri, 27 Mar 2026 09:17:33 +0000</pubDate>
                        <description><![CDATA[The filament was properly loaded and extruding, but once the small piece of PETG I had soldered to the beginning of the flexible filament had been extruded, the flexible filament jammed and ...]]></description>
                        <content:encoded><![CDATA[<p>The filament was properly loaded and extruding, but once the small piece of PETG I had soldered to the beginning of the flexible filament had been extruded, the flexible filament jammed and when I opened the idler I saw it had just bunched up in front of the gear, above the metal tube leading to the nozzle. This happened even though I had loosened the idler screws by two full turns following the recommendations at <a href="https://help.prusa3d.com/article/flexible-materials_2057" target="_blank" rel="noopener">https://help.prusa3d.com/article/flexible-materials_2057</a> and it happened during the loading procedure when I was purging the leading PETG part, so I didn't even get to printing, where I could have fiddled with the settings (speed, temperature, etc.).</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Spalan</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-787557</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-787555</link>
                        <pubDate>Fri, 27 Mar 2026 09:08:57 +0000</pubDate>
                        <description><![CDATA[did you try opening the idler and guiding the filament to the gears ?]]></description>
                        <content:encoded><![CDATA[<p>did you try opening the idler and guiding the filament to the gears ?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>tsamisa</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-787555</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-787548</link>
                        <pubDate>Fri, 27 Mar 2026 08:05:15 +0000</pubDate>
                        <description><![CDATA[Thanks, that worked for getting the filament loaded. But then the filament immediately jammed in the extruder. I&#039;ve now given up on printing really flexible filaments on the XL.]]></description>
                        <content:encoded><![CDATA[<p>Thanks, that worked for getting the filament loaded. But then the filament immediately jammed in the extruder. I've now given up on printing really flexible filaments on the XL.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-787548</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-781332</link>
                        <pubDate>Sun, 08 Feb 2026 06:34:01 +0000</pubDate>
                        <description><![CDATA[Use a solder pen or whatever to splice some pla/petg to the tip of the tpu to help guide it. Then extrude multiple multiple times to purge all of the guide tip material from the nozzle.]]></description>
                        <content:encoded><![CDATA[<p>Use a solder pen or whatever to splice some pla/petg to the tip of the tpu to help guide it. Then extrude multiple multiple times to purge all of the guide tip material from the nozzle.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>BaconFase</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-781332</guid>
                        <title>Loading flexible filament into Prusa XL Nextruder</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-780150</link>
                        <pubDate>Thu, 29 Jan 2026 16:11:24 +0000</pubDate>
                        <description><![CDATA[Dear all,
I have a very flexible filament (Filaflex 60A) that I&#039;m trying to load into my Prusa XL. The problem is that I cannot get the filament into the tool.
I am already bypassing the s...]]></description>
                        <content:encoded><![CDATA[<p>Dear all,</p>
<p>I have a very flexible filament (Filaflex 60A) that I'm trying to load into my Prusa XL. The problem is that I cannot get the filament into the tool.</p>
<p>I am already bypassing the side filament sensor and feeding the filament directly into the tool head, but the filament does not even reach the gears. I have cut it flat, I have cut it at an angle that gives it a very thin point, I'm twisting around, but no matter what I do, it seems to get stuck somewhere in the channel leading to the extruder gears. Loading stiff filaments or regular TPU is no issue at all, that works fine. It's just this very flexible filament that I find no way to load.</p>
<p>I'd appreciate any advice that someone may have.</p>
<p>Best,<br />Stefan.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/loading-flexible-filament-into-prusa-xl-nextruder/#post-780150</guid>
