dock-cable-router screw types attaching to metal piece with magnets in it?
KarmaPolice
(@karmapolice)
I received an assembly with one of the magnets reversed, I've gotten a replacement from Prusa, but they only sent the metal piece with the magnets in it, not the whole assembly... I know it's a 2.5mm hex to back the middle screw off the frame, but I can't figure out the screws above and below that to back the metal piece off the dock-cable-router... I would have though also 2.5mm, but seems to be smaller, but 2.0mm seems too small and spins "relatively" freely... of course the screw is also too far in for me to get a good eye on it... any help would be appreciated.
Posted : 15/12/2023 2:45 am
RE: dock-cable-router screw types attaching to metal piece with magnets in it?
could they be Torx Screws?
Posted : 15/12/2023 10:21 am
KarmaPolice
(@karmapolice)
Turns out that exactly what it was, Torx - same size as the screw driver shipped with the product, but had to use the key one that came with it instead as the screw driver shaft doesn't fit in the feed hole.
Thanks!
Posted : 15/12/2023 5:17 pm
Glad I could help
Posted : 16/12/2023 12:16 pm
