Change filament in multiple tools at single layer change (XL5T)?
SuperMatt
(@supermatt)
Utenti
Hey all, I'm trying to do an 8-colour print. I've designed a model (only 4 layers thick) where I need to swap 3 colours from 3 of my tools at the start of layer 3. Seems PrusaSlicer will only allow one change tool/filament change per layer? My model is thin, so I can't do the changes on subsequent layers. I've also tried queueing up M600 T1, M600 T2 using the custom G-Code but that didn't work at all, print just continued through without any changes.
Reading about this, seems I might need to trigger a pause/grab the tool I want to change mid-layer? Is this possible? Any other thoughts?
Thanks in advance
Questa discussione è stata modificata 2 days fa da SuperMatt
Postato : 15/06/2026 11:56 am
Pe3d
 Pe3d
(@pe3d)
RE: Change filament in multiple tools at single layer change (XL5T)?
Maybe you could solve that with sequential Print. Here are some thread about one Extruder multi colour prints:
https://forum.prusa3d.com/forum/postid/605834/
https://www.printables.com/model/666435-multi-color-test-model-for-single-extruder-without?lang=de
Postato : 15/06/2026 7:42 pm
Pe3d
 Pe3d
(@pe3d)
Maybe you could solve that with sequential Print. I havent played around with virtual Extruders but here are some thread about one Extruder multi colour prints:
Questo post è stato modificato 1 day fa da Pe3d
