Can a transparent filament be a wrong choice when calibrating the filament sensor if it's used later with a more opaque one?
Hello,
I've calibrated both filament sensors of my XL 2T using some transparent PETG.
However, I have then loaded a spool of Prusa Galaxy Black PLA on one printing head. On this head I've had an issue of false alarms of blocked filament. The filament was not blocked at all.
I am wondering if the calibration of the filament sensor should be run again when there is such a change between a see-thru filament and a much more opaque one.
Napsal : 01/04/2025 7:14 am
I don't think Prusa have used optical checks since the early Mk3. First check the diameter of the filament you used.
Napsal : 01/04/2025 7:38 am
amundsen se líbí
Topic starter
answered:
RE: Can a transparent filament be a wrong choice when calibrating the filament sensor if it's used later with a more opaque one?
It’s Prusament PLA…
Napsal : 01/04/2025 4:23 pm
Check the diameter of the transparent PETG you used for calibration.
Napsal : 01/04/2025 5:08 pm
amundsen se líbí
