side filament sensor how to disable
I would like to feed the filament into the nextruser as with the MK4 and mounte filament above the printer. So can I disable the side filament sensors and only use the sensor in the nextruder?
Opublikowany : 28/12/2023 9:00 pm
RE: side filament sensor how to disable
Just put a 3" piece of filament in the sensor for each Nextruder you have.
Opublikowany : 29/12/2023 2:13 am
Keep in mind that without the side sensor spool joining will not work,
Opublikowany : 01/01/2024 1:51 am
