RE: Prusa XL Build Thread - Two Head Version
Oh darn that's fancy thank you
The next step is to assemble the LCD and run the wires. Running the wires was the toughest stap. It was a pain in the behind. Once done, below, you can barely see them.
LCD Installed.
Now, you install the upper section. Again- 8 screws.
You can see the arms that support the print bed. They are mounted to linear rails.
Another view
It is upside down, but at the bottom is the electronics boxes and gantry. The two long objects are the power supplies. They are integrated and prewired.
No issue. Any other targeted photos?
is all the electronics like psu and buddy board prewired
I have been asked I I had any issues. I have one that is ongoing. My bed is higher in the back than in the front.
I did resolve one. My printer failed to recognize the filament on the second head and thought it was always loaded. I spent 3 hours on the phone with support sending them photos and videos. It was a corrupted firmware. A hard reset, and it fixed itself.
Yes. You have to plug in the fans, XYZ Axis, LCD, and sensors. It really is mostly complete. It saved my $500 and was well worth it.
Here is a close-up of the electronics.
You just have to run the wires in the photo below and plug them in.
First 2 color print:
nice looks good
about how long to assemble this? Crazy how assembled it really is.
Satin and textured.
Which sheets did it come with?
Print sheets - Check.
Ah, nice, so I only need to add the smooth if I'm able at the time I can finalize the order then.
Still waiting so I can switch my dual to five tool..
Satin and textured.
That is what I did. I have been pending mine shipping for about 10 days.
Satin and textured.
The next step is to attach the printer gantry. Again, about eight screws with the pre-installed Gantry. The top section or gantry came as a single assembled piece.
Next, I installed the bed and placed a box on the sheet to install the print heads. I missed a few photos, during the build. The bed instalation required 8 screws.
wow nice! thanks for posting all that!
