Option to select/confirm extruder appears sometimes not other times
Ira S
(@ira-s)
[I tried posting this on the Prusa Connect forum back on November 24, but no answers there]
I suspect I'm missing something simple, but still can't figure it out.
I use Prusa Connect to send jobs to my 5 head XL.  I do so via the dashboard and select the .bgcode file, which then gets transferred to the printer and run.
Sometimes, the printer puts up a screen allowing me to confirm (or perhaps change) which extruder to use. Other times it skips this step.
I like this extra step because it lets me know which print head(s) will be used in case I screw up and forget to assign the correct one(s) while slicing.
How do I get this step to happen all the time?  Must be something simple, but I don't see it.
Thanks.
Veröffentlicht : 30/12/2024 6:51 pm
Razor
(@razor)
RE: Option to select/confirm extruder appears sometimes not other times
If you figure this out please post the solution here because you aren't the only one. 😉
Mini+MK3S+XL 5 Tool
Veröffentlicht : 31/12/2024 12:31 am
