Misled by a Misrepresentation of a part
Reggie
(@reggie-3)
Recently, I ordered a Nextruder Hotend brass High Flow - 0.40 mm, and received a Nextruder Hotend standard flow 0.4 nozzle attached to the heater bloc. I wrote to Prusa and I am actually waiting for their answer, while waiting 24 hours later I returned  to the parts to find out on the lower left corner that this kit in fact was delivered by a standard nozzle...I'm really mad that they do things like that, if you advertise a parts being High Flow it's without a doubt the nozzle that is, not the bloc or the heater, wires. Can't wait to see what there answer will be...
Postato : 15/08/2025 12:20 am
Chris Hill
(@chris-hill)
RE: Misled by a Misrepresentation of a part
CHT is high flow.  Did you receive a CHT nozzle?  If it says CHT on your nozzle, you're good.  If not, they simply shipped the wrong part.
Postato : 15/08/2025 1:00 pm
1 persone hanno apprezzato
UjinDesign
(@ujindesign)
To further clarify, "CHT" stands for "core heating technology" which is a type of high flow nozzles. 🙂 Hope it gets sorted out for you!
Posted by: @chris-hill
Postato : 15/08/2025 3:26 pm
Reggie
(@reggie-3)
This is the nozzle I received with, to me it looks like the same old nozzle with the 3 dots that I still order for my MK3S+ ??? No CHT inscription on the nozzle...
Postato : 15/08/2025 7:22 pm
Reggie
(@reggie-3)
Sorry for the confusion regarding my lack of knowledge about the high‑flow nozzles.
It’s been some time since my last nozzle order for the XL, and my previous order was for high‑flow nozzles that were not CHT and had a different appearance. After checking with a flashlight, I can definitely see the three typical holes of the CHT, so I apologize for bothering you due to my lack of knowledge.
Postato : 16/08/2025 10:24 am
It should state what it is. The inscription is not on the actual nozzle but the shaft.
Postato : 20/08/2025 1:46 am
Reggie
(@reggie-3)
I've looked at it many times with a magnifying glass with an LED light and one thing is Shure, I compared with other nozzles that I have at home and other then part numbers that are different from standard to highflow or CHT. There is no CHT  inscription on the shaft or numbers that I can link to a CHT differentiation, It is written on the box when I received and I can see with the magnifying glass the typical three holes inside when I pointed the tip of the nozzle thru the monitor screen light.
thanks
Posted by: @foxrun3d
Postato : 20/08/2025 7:15 am
