Latest firmware 6.0.4 does seem to work well with high temp and enclosure
John McCauley
(@john-mccauley)
I was getting all kinds of random errors, tiles overheating, etc... The latest firmware so far has worked. Been able to print out my parts.
Certain parts use a filament that requires a high temperature and an enclosure. We are experiencing a heat wave in the Midwest. So not having a heater in the enclosure could be an issue in winter. Prusa would be great if you had a heater add-on with a temperature sensor that honoured the enclosure temperature setting in the slicer.
Veröffentlicht : 29/08/2024 12:43 am
JP Guitars
(@jp-guitars)
RE: Latest firmware 6.0.4 does seem to work well with high temp and enclosure
It is trivial to setup your own heater, buy something like this: https://www.amazon.com/dp/B083FJ7GKR/   have the sensor inside the enclosure with the switch outside, then add a small heater inside the enclosure.
Another alternative would be something like this: https://www.amazon.com/dp/B08XWTLVPV/   although as this does not give out a huge amount of heat you would need to consider whether the environment the printer was in would pull too much heat out for it to keep up.
Veröffentlicht : 29/08/2024 8:09 am
John McCauley
(@john-mccauley)
That is my fall back. Right now it is not an issue. Point being it would be more convenient if Prusa integrated the heater and sensor.
Veröffentlicht : 29/08/2024 12:09 pm
JP Guitars
(@jp-guitars)
Posted by: @john-mccauley
Agreed, but on past experience at four times the price...
Veröffentlicht : 29/08/2024 12:17 pm
