How to clean off the nubs from the bed??
How are you guys cleaning off the little nubs of filament left from the bed levelling procedure?
I’m using the satin sheet and love the finish on parts and almost universal filament stick.
PETG and TPU bits are particularly hard to get off.
Any tips that won’t ruin the finish on the sheet?
Every time. It'll end up messing up your bed mesh.
Those "nubs" are caused by filament stuck to your nozzle from previous prints.
I recommend heating your nozzle up to printing temperature for a few minutes before you start and clean it with a brass brush. Then preheat the printer and as the nozzle drops down to preheat temperature make sure it doesn't ooze anymore.
I do this before every print and it doesn't leave those "nubs".
A plastic scraper or your fingernail work to get them off.
Agreed. Make sure the filaments are bone dry, the nozzle clean and if you have a problem filament preheat it. A light plastic scraper will take off any rogues in the few seconds while the nozzles are coming up to temperature but do not apply pressure.
Cheerio.
RE: How to clean off the nubs from the bed??
I found out it is easiest to do it when Buildplate is cold with your Fingernails.
Works pretty well for me and did it with PLA, PETG, TPU and PC.
A note of caution about cleaning the sheet when it's on the bed.
Look at the construction of the bed. Look where it is supported. Now consider what happens when you press down hard to clean off a nub or a stubborn piece of TPU that just won't let go. The heat bed can easily be bent by that pressure.
There should be a note from Prusa stating that the sheet should be removed from the heat bed prior to cleaning. I think that's the smart thing to do since even the slightest bow in the sheet is going to throw it out of tolerance. Every print subsequently made will have that bow too.
If a simple wipe to light scrub with ipa doesn't get a nub off I usually just print a single layer square on top of them and peel it all off. Seems to work better than percussive nudging.
I have a small glass mirror tile (10 x 10 cm) laying next to the printer (very handy when checking backside of extruder; looking under the printer).
And use it for fast scraping the plate. The nicely rounded corner do not scratch, but are firm enough to remove every pimple on the plate.
I've used my fingernails as well.
You can avoid the nubs all together by editing the printer gcode. I had the same problem but mostly only with tpu and it irritated the crap out of me.
You just have to remember to change this when starting a new print job or save off a copy of the printer profile with this change.
In this picture, Change the highlighted 210 to 175 and the problem for flex(tpu) goes away. you can see handling of other filament types there so adjust those accordingly if you're having trouble with them. I'd love to get prusa to simply change this 210 to 175 by default since 210 is WAY too hot.
I went ahead and opened this issue on github
https://github.com/prusa3d/PrusaSlicer-settings/issues/243
I'm not sure why 210 was chosen for flex, but perhaps they'll be willing to change the default to avoid the nubs/dots.
when i print petg, tpu or abs i put it not to the first tool head i put in the first pla filament
in prusa slicer i also add a small 1 layer pla print (a square for example) so the nozzle clean and the first layer calibrations are with pla
Ouais, ces petites bosses de purge/nivellement peuvent être ennuyeuses, surtout avec du PETG et du TPU sur une feuille de satin. La première chose que j'éviterais est tout métal qui pourrait rayer la surface. Habituellement, je laisse le lit refroidir complètement, puis je fléchis doucement le drap, ce qui fait souvent ressortir la plupart d'entre eux. Pour les morceaux tenaces, un grattoir en plastique fonctionne bien. S'ils sont vraiment fondus, essayez de réchauffer légèrement le lit (pas de température d'impression, juste chaud) et décollez-les soigneusement. Un nettoyage régulier avec de l'eau tiède et un peu de savon à vaisselle aide également à maintenir une adhérence équilibrée sans endommager la finition.
Oui, tu as déjà les bons réflexes. Sur une feuille satinée, le plus important c’est vraiment d’éviter le métal pour ne pas marquer la surface. Laisser refroidir complètement puis plier légèrement la plaque, c’est souvent suffisant pour casino neteller https://www.villeinitalia.fr/neteller-casino/ faire sauter les petites bosses. Pour le PETG ou le TPU un peu collés, un grattoir plastique reste la solution la plus sûre. Et le petit coup d’eau tiède avec liquide vaisselle de temps en temps, ça aide à garder une accroche propre sans abîmer la finition.
