6.4.1 Beta Firmware for the Prusa XL
Jan Kratochvíl
(@jan-kratochvil)
Utenti Admin
Summary
  • Improved phase stepping calibration
  • Fixed homing issues with no tool picked
  • Fixed toolchanger service moves being affected by user feedrate override
  • Relaxed nozzle cleaning checks to prevent false nozzle cleaning failed errors
  • Relaxed print fan selftest thresholds to reduce false failures
  • Known issue - Power panic resulting in a BSOD
This is the beta release of firmware 6.4.1 for the Prusa XL, bringing targeted stability improvements and fixes — most notably addressing several homing and toolchanging reliability issues.
The switch to the new universal phase stepping calibration in the 6.4 release caused a regression in the calibration quality for some XL users. The calibration method has been tuned to mitigate these issues.
Release notes
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.4.1-beta
Homing without a tool picked could cause audible motor skipping or put the printer into an invalid state under certain conditions. The fix ensures that the axes are properly homed before attempting a tool pick, preventing both issues.
Tool parking, picking, and alignment moves could be slowed down if a low feedrate was set in G-code beforehand. This could lead to unreliable tool changes. All toolchanger service moves now run at their intended speeds regardless of the user feedrate setting.
The print fan selftest could incorrectly report a failure on some units due to tight RPM thresholds that did not account for normal fan-to-fan variation across different fan shroud revisions. The thresholds have been relaxed to reduce false failures.
Postato : 04/03/2026 6:08 am
Nagoya kogei
(@nagoya-kogei)
Utenti
RE: 6.4.1 Beta Firmware for the Prusa XL
Hi, I updated from 6.2.6 to this beta version, but I'm getting an error during phase-step calibration.
The first problem is that if you run phase-step calibration alone, it will start operation without picking up a tool.
Until now, the tool would always be picked up and calibration would start.
I have confirmed that if I run phase-step calibration with tool (T1) attached, it completes successfully without any errors.
Please check that it works properly.
Postato : 06/03/2026 9:42 am
adesir
(@adesir)
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/5147
Mes modeles publics
Postato : 06/03/2026 2:26 pm
mgantner
(@mgantner)
6.4 cost me a lot of filament and many multiday print failures. I've lost confidence. I think I'll just remain one release firmware behind at all times. Took way too long to admit 6.4 was a problem.
Postato : 06/03/2026 2:57 pm
JavaBean
(@javabean)
one of the problems with them admitting 6.4 was a problem is that many people had no issues with 6.4.  i myself have done several multi-day, multi-tool prints on 2 different xl's both running the 6.4 release.  at this time i have no reason to revert, 6.4 is stable for me.  and many others as well
Postato : 06/03/2026 4:35 pm
BullDog8484
(@bulldog8484)
So, yeah, of my two XL's, one was completely stable on 6.4.0.  The other had intermittent toolhead crash and homing issues.  Rolling back to 6.2.6 fixed everything.  But I'm now testing 6.4.1 on the problem machine and so far, it's rock solid, and quieter than 6.4.0 was.  I'm not 100% confident, but I'll move to some small production runs to stress it.  6.2.6 is on hot standby just in case.
Postato : 07/03/2026 9:45 am
ErikSimon
(@eriksimon)
Utenti
I installed it to try out, the printer is atleast not trying to break itself apart like on the 6.4.0. However it still won't even get passed the probing. Neither 6.4.0 or 6.4.1 is able to complete the probing. I've tried both dimonback nozzle, Obxidian, Prsua XL PA bed and Prusa xl Satin bed.
I'm going back to 6.2.6.
Postato : 07/03/2026 7:38 pm
BullDog8484
(@bulldog8484)
A little over 100 hours of printing on 6.4.1 Beta. Multiple models, nearly 1500 tool changes. No issues at all. Print quality looks to be a little better. Maybe because of the phase stepping now working.... Maybe? Will continue testing, but very pleased so far.
Postato : 11/03/2026 11:31 pm
dmbgo
(@dmbgo)
I second that BullDog8484. My 5T xl is working well with this beta version. Previously, if I didn't remember to clean the print head b4 starting a print, it would always say printhead cleaning failed.
Postato : 16/03/2026 5:08 am
bsw
 bsw
(@bsw)
Utenti
My 5T XL seemed to work O.K. with 6.4.0 I had a couple tool crashes but detaching prints seemed to be the cause. I switched to the 6.4.1. Beta and everything seems fine so far, my only issue is when I run the input shaper calibration it complains that the frequencies are too low (X and Y) and I need to tighten the belts. Howeve my gantry is square and my belt frquecies are 88/91 which the Betlt tuner says in slightly high. I ran a Homing tower to verify and it was flawless. I tightened the belts so more to see if it helped but no workee.... Still need to maybe w=switch back to 6.4.0 or 6.2.6 to see if input shaper works.
Postato : 25/03/2026 12:10 am
dsolana
(@dsolana)
Utenti
After upgrading from firmware version 6.2.5 to 6.4.1-RC during the new calibration steps, the toolhead crashes with the filament sensor calibration tests.
Postato : 10/04/2026 5:23 am
