6.4.0 Firmware for Prusa XL
Page 2 / 2
Carl A
(@carl-a)
RE: 6.4.0 Firmware for Prusa XL
The check is under Settings>Hardware>G-Code Checks and it has 3 options off, warning, strict
Posted : 12/12/2025 5:46 pm
Maybe it is always on now.
It is always on in firmware now. So you need to update your printer profiles in Configuration Assistant to Original Prusa XL-5T Input Shaper, to avoid getting the g-code warning. Or disable the warning as described above but I would suggest updating your 3mf project files with the new printer settings.
Posted : 12/12/2025 5:59 pm
Carl A
(@carl-a)
Not sure whare to find Configuration ASSISTANT in Slice 2.9.4. I have looked at Configuration Wizard, check for configuration updates and application updates. Everything says that I am up to date.
Posted : 12/12/2025 6:57 pm
Carl A
(@carl-a)
Looked in the wrong place. Have found it and applied. Had been usinging the Original 5T .4 nozzle before. Thanks.
Posted : 12/12/2025 7:03 pm
Carl A
(@carl-a)
Page 2 / 2
