					                		XL dual tool - print fan self test fails on both extruders - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/</link>
                <lastBuildDate>Fri, 12 Jun 2026 11:07:44 +0000</lastBuildDate>
                        <title>RE: XL dual tool - print fan self test fails on both extruders</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-730370</link>
                        <pubDate>Sat, 21 Dec 2024 18:02:19 +0000</pubDate>
                        <description><![CDATA[(Added this to another XL-fan-prob thread) For others who find this post: I had the same issue (after doing a hotend swap), I attempted the fan test calibration to make sure I didn&#039;t mess an...]]></description>
                        <content:encoded><![CDATA[<p>(Added this to another XL-fan-prob thread) For others who find this post: I had the same issue (after doing a hotend swap), I attempted the fan test calibration to make sure I didn't mess anything up and the test started failing (yet both fans running/working). Rather than trying to dissemble anything (again), I took a small portable vacuum and had it running/sucking close to the exhaust port of the failing fan. Ran the check with the vacuum running and it passed the test. ***Disclaimers: some types of fans when ran 'externally' will produce voltage, which might or might not damage any connected circuitry. Attempt this at your own risk. I minimized the chances by not having the vacuum directly coupled to the exhaust shroud and I only started the vacuum after the fan was running (to assist it getting to whatever speed the test wanted). </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>EyeZack</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-730370</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-725734</link>
                        <pubDate>Tue, 29 Oct 2024 21:30:17 +0000</pubDate>
                        <description><![CDATA[Just adding another data point... my brand-new 2-head XL is failing the print fan RPM test also. Ran the test a few times and got 1 fan to pass once. Removed the fan ducts and then both pass...]]></description>
                        <content:encoded><![CDATA[<p>Just adding another data point... my brand-new 2-head XL is failing the print fan RPM test also. Ran the test a few times and got 1 fan to pass once. Removed the fan ducts and then both passed.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Byte Arts</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-725734</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-723072</link>
                        <pubDate>Fri, 27 Sep 2024 21:45:31 +0000</pubDate>
                        <description><![CDATA[XL dual tool- print fan self test fails on both extruders.Has PRUSA arrived at a definite solution for this persistent problem?I have had identical problems with printer fans test failure on...]]></description>
                        <content:encoded><![CDATA[<p>XL dual tool- print fan self test fails on both extruders.</p><p>Has PRUSA arrived at a definite solution for this persistent problem?</p><p>I have had identical problems with printer fans test failure on both tools .  I have removed the shrouds of both printer fans.  This transiently worked on tool 2 but not tool 1.  Tool 2 would only pass intermittently with multiple tries.  Tool 1 never passed testing. </p><p>All fans are spinning and blowing air, run quiet and have unobstructed air flow.</p><p>I've tried compressed air to blow out  printer fans and checked for burrs.  Nothing seems to help.  Firmware version is 6.0.0.</p><p>Any and all suggestions would be appreciated.<a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/09/d24c9bbc-prusa-xl-print-fan-test-results-scaled.jpg"><img class="alignnone size-medium wp-image-170658" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/09/d24c9bbc-prusa-xl-print-fan-test-results-600x500.jpg" alt="" width="600" height="500" /></a></p><p>PRUSA Chat frustrating.  They want videos of all tools including  the fans and tool hot ends, videos of the complete self test.</p><p>I have difficulty attaching videos to Email but have enclosed photos. of tools and test result.  Not sure of any additional info in video.</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Jim Spence</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-723072</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-711184</link>
                        <pubDate>Fri, 17 May 2024 05:24:07 +0000</pubDate>
                        <description><![CDATA[Good morning, yesterday I updated the firmware version to 6. When I did the fan test, as you can see I got an error, as you can see in the photo.I have solved the problem in a much simpler w...]]></description>
                        <content:encoded><![CDATA[<p style="text-align: justify"><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/05/ecb180dd-img_20240516_151729-scaled.jpg"><img class="alignnone size-medium wp-image-167267" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/05/ecb180dd-img_20240516_151729-600x500.jpg" alt="" width="600" height="500" /></a></p><p>Good morning, yesterday I updated the firmware version to 6. When I did the fan test, as you can see I got an error, as you can see in the photo.</p><p>I have solved the problem in a much simpler way. Look at the fan on the right (the one that fails) and possibly some dust has accumulated. Therefore, it does not reach the RPM of the test.</p><p>In my case, I have an air compressor, I put a nozzle on it to clean dust and clean the fan using pressurized air. (If you don't have a compressor, you can buy a can of compressed air at computer stores to clean computer components). </p><p>So, after cleaning the fan on the left mainly (and the one on the right). When the test was repeated again, the test was passed. 😎 </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Manuel.De.Escayola</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-711184</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-711172</link>
                        <pubDate>Thu, 16 May 2024 22:16:00 +0000</pubDate>
                        <description><![CDATA[I went back to v5 firmware, still had a fail.. weird. Took the fan off the head, removed shroud and tested.  All 5 fans passed. Careful assembly, re-test problem gone. Could not get away fro...]]></description>
                        <content:encoded><![CDATA[<p>I went back to v5 firmware, still had a fail.. weird. Took the fan off the head, removed shroud and tested.  All 5 fans passed. Careful assembly, re-test problem gone. Could not get away from FUSB302B blue screen error in firmware v6.0.0. Apparently it should be addressed in firmware v6.0.xx </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>XL beta tester for far too long</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-711172</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-710348</link>
                        <pubDate>Wed, 08 May 2024 16:44:13 +0000</pubDate>
                        <description><![CDATA[Interesting, admittedly I&#039;ve not rerun the fan calibration since I installed. 6.0.0.   Now I&#039;m not going to.]]></description>
                        <content:encoded><![CDATA[<p>Interesting, admittedly I've not rerun the fan calibration since I installed. 6.0.0.   Now I'm not going to.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>ssill2</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-710348</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-710347</link>
                        <pubDate>Wed, 08 May 2024 16:43:50 +0000</pubDate>
                        <description><![CDATA[Just took on firmware 6.0.0 now all my print fans are failing on my 5 head XL. No reply from support since yesterday.]]></description>
                        <content:encoded><![CDATA[<p>Just took on firmware 6.0.0 now all my print fans are failing on my 5 head XL. No reply from support since yesterday.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-710347</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-710346</link>
                        <pubDate>Wed, 08 May 2024 16:40:43 +0000</pubDate>
                        <description><![CDATA[Just took on firmware 6.0.0.0..... ALL my print fans are failing .!. OMG]]></description>
                        <content:encoded><![CDATA[<p>Just took on firmware 6.0.0.0..... ALL my print fans are failing .!. OMG</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-710346</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-687793</link>
                        <pubDate>Tue, 05 Dec 2023 06:49:36 +0000</pubDate>
                        <description><![CDATA[Glad you found the issue!]]></description>
                        <content:encoded><![CDATA[<p>Glad you found the issue!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>CleverSquirrel</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-687793</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-687768</link>
                        <pubDate>Mon, 04 Dec 2023 23:42:07 +0000</pubDate>
                        <description><![CDATA[so I just reran the fan calibration, and it of course failed, several times.  I think noticed that 1 and 5 seemed to be failing on the part fan consistently.   visually they spin up just as ...]]></description>
                        <content:encoded><![CDATA[<p>so I just reran the fan calibration, and it of course failed, several times.  I think noticed that 1 and 5 seemed to be failing on the part fan consistently.   visually they spin up just as they should.    I went I had and unscrewed part fan and shroud and put inspected.  no issues.  they were tightened pretty good though, so when I put back on I I finger tightened them.  Ran the calibration again and bingo.  I noticed everything on the factory assembled side were very tight, including the idlers etc.   I had to mess with idler tension a bit when trying to print tpu the first time.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/xl-dual-tool-print-fan-self-test-fails-on-both-extruders/paged/2/#post-687768</guid>
