Trouble printing with soluble supports (PVA or Verbatim BVOH)
Page 2 / 2
rassiasn
(@rassiasn)
RE: Trouble printing with soluble supports (PVA or Verbatim BVOH)
Nice to hear that your results are improving!  I have also had some luck recently... I switched from verbatim to aquasys 120.  I found that I could run aquasys at a higher temperature than verbatim.  I'm not saying that the aquasys likes being printed at 235-240 degrees C, but it seems to tolerate it.  I also bumped my printing speed for the support material just to keep the filament flowing well and I haven't run into any issues yet.  I still need to try using two different nozzles sizes, 0.6mm for PLA/PETG and 0.4mm for PVA.  I was also able to get the nozzle adaptor sold by prusa so I can use my old E3D V6 nozzles.  Maybe that'll make a difference?
Publié : 07/12/2023 8:31 pm
1 personnes ont aimé
ssill2
(@ssill2)
yeah, but with the aquasys you can print it at a nozzle temp that works and then just adjust the bed temp to match what you're having share the first layer with.  bvoh was definitely my goto on the MK3S + MMU.  Aquasys flat out wouldn't work in the mmu.  But it seems made for the XL lol
Publié : 07/12/2023 9:52 pm
ssill2
(@ssill2)
so I just thought I'd follow up with this.
I just completed a 4.5 day print  with petg + aquasys 120 for soluble interfaces.
E1 = Prusament Jet Black PETG
E2 = Giantarm Silver PETG
E3 = Aquasys 120
It's not perfect, but that's mainly because I think I need to tune the temps a little, but it turned out well enough, and I think it proves that the aquasys works pretty well as a soluble interface.
I ended up using snug supports since organic supports tipped over on me on my first attempt.  This added SIGNIFICANTLY to both filament usage and the print time, like double.  and this is what the core support looked like after I detached it.  supports that tall start getting less stable, as you can see with the waviness.   If I were to print this again I'd probably try to support settings and I might try to dial in temp settings a bit.
Publié : 17/12/2023 3:26 pm
ntdesign
(@ntdesign)
Just a suggestion, why not quickly design some sort of filler block under the helmet? One wall, lightning infill, 3-4 top layers. Then just put supports between that and the helmet. That should save significant time and material.
Publié : 18/12/2023 1:23 pm
3 personnes ont aimé
ssill2
(@ssill2)
Yeah that’s a good idea.  I want to do a Vader helm and I might try it down r that.  Thanks!
Posted by: @ntdesign
Publié : 18/12/2023 2:15 pm
rassiasn
(@rassiasn)
Hi everyone!
It's been a while, but I finally have an update.  I switched from a 0.6mm nozzle to a 0.4mm and my results immediately improved.
I also have switched from Verbatim BVOH to Polymaker Polydissolve S1, as I am unable to source the Verbatim.
Currently, I am printing the Polydissolve around 230-235 C.
Publié : 10/04/2024 7:11 pm
Tim B
(@tim-b)
Membre
Would you be willing to share all the material settings you used for the AquaSys 120.  That is Bed Temperature, Extruder Temp, lift height, extraction rate, and other settings for this filament that you used?  I have been trying to get a print to work with 4 different materials and BVOH as I need water soluble supports but no luck.  Based on your journey above, I am trying to see if I can get this to work with AquaSys 120 but not sure the optimal settings for the XL
Publié : 03/07/2024 1:46 am
burdickjp
(@burdickjp)
Posted by: @rassiasn
Hi everyone!
Are you otherwise using the Verbatim BVOH settings? I'm having trouble with PolyMaker PolyDissolve and CookieCAD PLA. I'm trying to do interface in PolyDissolve and it isn't behaving well.
Publié : 20/12/2024 12:35 pm
Finalfill
(@finalfill)
Membre
I got it working!
I was having a really frustrating time printing with BVOH. It was not adhering to itself, not creating clean lines, balling up all over and getting stuck/wrapped in the extruder on every unload.
I had actually given up on it and moved to painting on release agent for the support interfaces. That turned out to be unreliable and way too much work, so I thought I'd give the BVOH another go and finally got it laying down clean layers.
Setup:
Filament -Verbatim BVOH 1.75mm OD
Printer - Prusa Core One w/ MMU3 - below testing was done with 0.25mm nozzle.
Slicer - PrusaSlicer 2.9.4
Filament profile was a copy of the Prusa default Verbatim BVOH profile with the below changes made.
What helped:
1. Huge extrusion factor of 1.18. This was the thing that had the most impact on the result. With an EF of around 1.05, I saw a small improvement, so I kept pushing it.
2. Low temperature gives cleaner results (smoother and more transparent). Benefits of this started showing below 200C. I have mine set to 178C - just above the melting point. I’m seeing no stringing and the prints are looking great.
3. The MMU unloading issue was solved by setting ramming time to the minimum so that“No Ramming At All” is displayed in the ramming customisation window. Setting is found in Filaments>Advanced>Ramming Parameters>Total ramming time (s). Note that this leads to oozing on the wipe tower but I can live with that. If I find a fix for that I’ll update.
Notes:
My filament is dry but not bone dry- I'm verifying the density by weighing 15cm lengths using a small digital scale, they’re averaging 0.41 grams. I'm also printing from a filament drier set to 50C.
Everyone says that you need to print BVOH slow, but I found it’s quite happy to print fast with the above settings. I pushed to 120mm/s with minimal loss in quality (I had to increase max volumetric flow to 6mm^3/sec for that speed).
Let me know if I missed anything.
Publié : 13/02/2026 4:08 pm
Page 2 / 2
