2T to 5T upgrade: pay attention to this during assembly - incorrect information in assembly guide!
Hello,
The upgrade user guide states that extruders with blue fittings (older ones) and the ones with black fittings (newer ones) are totally identical. Actually this is not true. The connection between the electrical cable and the toolhead is different. On the black joint version the cable is screwed to the toolhead whereas on the blue joint these screws don't exist. So be sure to that the order of the nextruder cables (ch. 16) and (ch. 29) do match. This is especially important to keep in mind if you have installed different nozzles and want them in a specific order on the printer.
Publié : 29/08/2025 10:52 am
