Spool holder with bearings- new design- feedback appreciated
bomtarnes
(@bomtarnes)
Hi all- just published this after testing for the last few days- https://www.printables.com/model/527008-prusa-xl-filament-roller
Any feedback is welcome, tweaks, positive, negative.
Opublikowany : 14/07/2023 10:15 am
Hello
(@hello)
RE: Spool holder with bearings- new design- feedback appreciated
Looks nice I like the roller design any chance you could make for the mk3 to
Opublikowany : 14/07/2023 10:22 am
bomtarnes
(@bomtarnes)
There are loads of designs out there for the mk3- they were my inspiration for this. I use one similar to this on my mk3: https://www.printables.com/model/208968-prusa-mk3-spool-holder-smooth-bearing-roller-editi
Opublikowany : 14/07/2023 10:57 am
LinkDJ
(@linkdj)
I like this design, but what's going to keep the spool from falling off the end?
Opublikowany : 18/07/2023 7:15 pm
bomtarnes
(@bomtarnes)
The roller is slightly smaller than the bearings; this wasn't the case in my first design!
It now provides good positive retention.
Opublikowany : 19/07/2023 2:56 pm
1 ludzie polubili
Hello
(@hello)
I might try that I knowbits a big Chace but could you change the connecting end to fit in the slots of a replicator 2 if you download the replicator 2 spool holder then add that end to this one it would be amazing and I would much appreciate it
Opublikowany : 19/07/2023 7:47 pm
René
(@rene-3)
Well here he is.
main-body-short-v6_remix
Opublikowany : 20/07/2023 6:43 am
Hello
(@hello)
Thanks so much
Opublikowany : 20/07/2023 9:01 am
ssill2
(@ssill2)
I'm also finalizing a design with bearings.  in my case I needed one that would also work with the 3d upfitters enclosure on it.   I have one on the right side now I'm printing one for the left to verify design.  Then I'll probably post.
Opublikowany : 07/12/2023 11:38 am
ssill2
(@ssill2)
Here's what the right side looks like.  I may make some adjustments to the spindle to be slightly longer but this is the idea.
Opublikowany : 07/12/2023 12:24 pm
ssill2
(@ssill2)
Left side.  I have a new spindle that's longer that I'm printing.
Opublikowany : 07/12/2023 7:28 pm
1 ludzie polubili
ssill2
(@ssill2)
Not to shanghai the topic but the above is available on printables
https://www.printables.com/model/673222-prusa-xl-spool-holder-with-bearings-that-fits-with
this is meant to work with 3D upfitters enclosure.  I should have a full set printed by morning
Opublikowany : 08/12/2023 2:21 am
ssill2
(@ssill2)
There’s a pretty good one for mk3/4 I’ve been using that inspired my design.  Look for filler on printables
Posted by: @hello
Opublikowany : 08/12/2023 2:25 am
