Spool holder with bearings- new design- feedback appreciated
Hi all- just published this after testing for the last few days- https://www.printables.com/model/527008-prusa-xl-filament-roller
Any feedback is welcome, tweaks, positive, negative.
RE: Spool holder with bearings- new design- feedback appreciated
Looks nice I like the roller design any chance you could make for the mk3 to
There are loads of designs out there for the mk3- they were my inspiration for this. I use one similar to this on my mk3: https://www.printables.com/model/208968-prusa-mk3-spool-holder-smooth-bearing-roller-editi
I like this design, but what's going to keep the spool from falling off the end?
The roller is slightly smaller than the bearings; this wasn't the case in my first design!
It now provides good positive retention.
I might try that I knowbits a big Chace but could you change the connecting end to fit in the slots of a replicator 2 if you download the replicator 2 spool holder then add that end to this one it would be amazing and I would much appreciate it
Well here he is.
Thanks so much
I'm also finalizing a design with bearings. in my case I needed one that would also work with the 3d upfitters enclosure on it. I have one on the right side now I'm printing one for the left to verify design. Then I'll probably post.
Not to shanghai the topic but the above is available on printables
https://www.printables.com/model/673222-prusa-xl-spool-holder-with-bearings-that-fits-with
this is meant to work with 3D upfitters enclosure. I should have a full set printed by morning
There’s a pretty good one for mk3/4 I’ve been using that inspired my design. Look for filler on printables
