Support structure strength issue
Hello friends,
Just got my SL1 kit assembled and dialling in the setting with the Prusa Orange Tough
I have the following print at 0.05mm layer, 8/35 exposure, 2mm support diameter but I kept having part of the print getting tear off from the support. I also got a bit of warping on the base.
Anything I am missing from the settings?
The same file prints okay on my Anycubic Photon.
RE: Support structure strength issue
Make sure that your platform is properly secured and leveled. For some reason after the Wizard process my platform was never leveled properly and I was having similar issues to what you describe. I manually leveled the platform with a bubble level and my issues went away. My LCD prematurely failed and since installing the new LCD the auto-leveling wizard is working fine and printing works without the manual leveling.
@gnat
Thanks, platform leveling do you mean the whole SL1 machine or the build plate?
Leveling the entire printer is a good thing to do, but the build plate in relation to the printer is the important part. That is of course easier if the printer itself is already level.
