Quick Tip: How to easily hollow a model with Pepr3D
Pepr3D is free software that is intended to turn a single-colour object into a multi-colour object using face painting.
But you can use it also to hollow a model for SLA printing:
- first import your object
- you can add drain holes with the "Brush" tool (optional):
- select the bush tool and the second colour
- double click or drag the "Size" option to adjust the size of the holes
- paint the holes on the bottom of your object
- go to the "Export Assistant" tool
- in most cases, we need the "relative to SDF" option for clean results
- deselect the second colour
- Set the wall thickness by the "Depth" option
- "Update extrusion preview!" and readjust if necessary
- "Export files" if you are happy with the result
It is easier to use than Meshmixer but also a bit buggy and needs a lot of time for complex objects. But it doesn't crash (unlike Meshmixer).
Publié : 08/02/2020 11:03 am
